Old 30th November 2007, 09:26 PM   #1
Default BOSOZ help
Ive built a 2 chassis BOSOZ, Ive tested the power supply along time ago without issue. Everything is dual mono, including the same transformers from Nelson's article. Ive increased the power supply capacitance to 14,000 microfarad and changed C103-106 from 10 uf to 100 uf. Everything else is the same as the article except for Harris diodes to build the bridges
The preamp chassis connects via an "umbilical cord". I also have a separate wire that connects both chassis grounds together.
When I was adjusting the preamp's gain and input pots, I think I overloaded the imput of one channel as dumb *** me had his scope probe on x10. What would the amplitude limit on the inputs??? As I i had a 20 volt sqare wave coming into it for a brief time. Would this cause damage??
I also found that I fried one of my power supply channels(took out the bridges, zeners, and mosfet) after some testing. I dont think I shorted anything and sure cant find any potential shorts so Im in the proccess of repairing the power supply for that channel.
Can someone please explain what C103-106 do and especially if its a problem that Ive increased that capacitance from 10uf to 100uf each? Could this be any cause of concern??
Thanks,
Tom
In The Days Before Rock 'n ' Roll
Old 30th November 2007, 09:40 PM   #2
The one and only
Nelson Pass's Avatar
Default Re: BOSOZ help
In a word, no.
Old 3rd December 2007, 01:23 AM   #3
Well, I don't have a schematic in front of me, but I will take a stab at it. If those were 10uf each, then one is to filter the ripple off of the zener stack so the gate of the mosfet gets a nice ripple-less input. The other one (assuming it is connected between the output and the ground) is just filtering off some high freqency noise that might be at the output of the regulator. I changed that one to 100uf as well, no problems. It shouldn't be problem with the zener stack filter either (but I didn't try it, so I could be wrong).
The BOSOZ power supplies are a bit touchy. Mine went "poof" (burnt bridges) and I never did figure out why. The preamp circuit seems to be pretty robust, though.
JJ
Old 3rd December 2007, 06:24 AM   #4
Thanks Nelson!!! for making my speaker sing!!!
I was thinking i must have screwed somethin up
Old 3rd December 2007, 06:28 AM   #5
Another
Old 3rd December 2007, 06:30 AM   #6
one at a time
Old 3rd December 2007, 06:32 AM   #7
Thanks Jupiter June
Old 3rd December 2007, 06:33 AM   #8
and....
Old 3rd December 2007, 06:35 AM   #9
Old 3rd December 2007, 07:32 PM   #10
Default Should I heatsink my bridge diodes??
Im using 4A/600 V Harris "stealth" soft recovery diodes on my power supply. To repair a one channel I have to use 4a /600v Fairchild "stealth" soft recovery diodes as I couldnt find the Harris ones.
Should I heatsink these diodes?????? I didnt think they I needed them but now I wonder as I had a power supply channel fail and I cant figure out why.
Thanks!!
Tom
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 02:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 12:55 AM
Bosoz lawbadman Pass Labs 5 14th July 2003 02:10 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 06:22 PM
Page generated in 0.10432 seconds (80.39% PHP - 19.61% MySQL) with 11 queries
