Old 17th February 2003, 01:42 AM   #1
Default Bridge rectifiers for Aleph
Hi, I see all Aleph's series , Nelson used only 1 bridge rectifier, but many diy project on "passdiy" they usually used 2 bridges, is any different ?
Old 17th February 2003, 02:29 AM   #2
Jay is offline Jay  Indonesia
It surprised me if Mr. Pass used only one bridge (for 2 channels). One bridge for two channel means one transformer for two channels, or both channel share the same transformer.
Using dedicated power supply to each channel you will get better separation (you know what I mean).
May be you saw a monoblock, may be not. Mr. Pass is supposed to have built plenty of Alephs, so some of them may be with dedicated power supply, some with shared power supply.
Dedicated power supply may be not economical (if we talk about price to performance ratio). But Audiphiles always choose the non-economical way. As an audiophile and a businessman, I think Mr. Pass had managed to build both.
Old 17th February 2003, 01:19 PM   #3
dwjj's Avatar
I've seen a single bridge going from positive to negative rail.
There's also 2 bridges, one from positive rail to ground, the other from ground to the negative rail. Are the peak currents lower in each bridge? Is the resulting ripple better or anything? There has to be some reason to go through the extra trouble.
That can be separate from whether there's a separate supply per channel.
It's cheaper than a movie, and there's free coffee.
Old 18th February 2003, 10:08 AM   #4
ElectroNick's Avatar
I made a bridge just like Peter. But i have doubts about the wiring. If anybody knows if ts's wrong or right, please let me know.
Nick
Old 19th February 2003, 02:21 PM   #5
As long as the circuit is right, I cannot see why there should be a problem with the wiring. I only have a little doubt on the capacitors.
I guest the transistors are double pined (diode) and the caps are in parallel with each diode, and the caps are at least 100n. I won't hear any different whether the caps are 100n, 10n, or null, but I will have a bad feeling using 100n. I'll prefer 10n.
Old 19th February 2003, 02:32 PM   #6
Hi Jay
Do you have any experience with thes bridges ? That 10n value, did you calculate it or is it a commonly used value ?
I also downloaded that snubber/rectifier formula, but didn't get a proper calculation yet.
The value used on this bridge was chosen after reading about 'm on the net.
Grtz,
Nick
Old 19th February 2003, 02:33 PM   #7
Sandy H.'s Avatar
Sorry I can't answer your question, Electro-Nick, but could you point me to the link where this rectifier assembly is described by Peter? I am completely unsure of the capacitor application and wanted to learn a little more about it.
Thanks!
S.
Old 19th February 2003, 02:42 PM   #8
Hello Sandy,
I guess this is the link where i found it. The formula is posted somewhere else... please don't ask me where.
I think if you search on "snubber" and "caculation" you'll find it.
Suxes !
Grtz
Nick
Old 19th February 2003, 03:13 PM   #9
Sandy H.'s Avatar
Thanks, that's what I was looking for!
S.
Old 19th February 2003, 03:16 PM   #10
UrSv is offline UrSv  Sweden
UrSv's Avatar
Thanks!
S.
The single caps is a simplification of the snubber which might help and it might not. The source used in this forum seem to be mostly:
http://131.109.59.51/images/pdf/Calc...m_Snubbers.pdf
UrSv
Those who say it can't be done should not stop those who are doing it.
What does .01 cap on bridge rectifiers do? reiver Solid State 10 4th December 2008 01:21 PM
Aleph 4 Bridge rectifiers PixelPlay Pass Labs 3 19th January 2008 09:44 AM
Old Motorola Bridge Rectifiers? paulb Parts 6 7th February 2007 09:17 PM
fast bridge rectifiers slogan2112 Solid State 24 25th October 2004 09:51 PM
Bridge rectifiers in PSU Speek Solid State 6 16th August 2002 07:50 AM
Page generated in 0.11337 seconds (82.26% PHP - 17.74% MySQL) with 11 queries
