Old 16th February 2003, 11:27 PM   #1
Default Blue Diode as Power Indicator
As it seems the blue LED is the only way to go for a power indicator, I have a dumb question. I read where others have wrapped a couple of turns around the toriodal power transformer to energize the light.
I just ordered a couple of Lumex "Ultra Super Blue" panel mount LED's for my upcoming projects. My question is how the diode lives with the AC coming off the transformer.
I trust others, but most I have seen work off the DC heaters on tube gear. Can you feed them AC without smoking these 5.00 each jewels?
TIA,
George
Old 16th February 2003, 11:33 PM   #2
The one and only
Nelson Pass's Avatar
I have never done this. It's a lot easier to simply
place the LED in series with a resistor between the
+ and - supplies. Makes a nice supply bleed-down
circuit, also.
Old 16th February 2003, 11:50 PM   #3
jackinnj's Avatar
Default it is a diode after all
super blues -- Agilent high lumninosity are less expensive.
Old 17th February 2003, 12:09 AM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
In my latest Gainclone project it was more convenient for me to wrap 10 extra turns on a toroid for a blue led. I connected it through regular rectifying diode and intensity adjustment resistor. Works fine.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th February 2003, 10:22 AM   #5
Default Blue diode wiring
Thanks for the advice on parts needed. I will wrap wire and measure voltage untill it gets to the proper range.
If there are replacements needed I will look into the Agilent LED's. The blue models are not available locally. But that is what is great about the net!
George
Old 17th February 2003, 11:17 AM   #6
miguel2 is offline miguel2  Portugal
I use some turns of bell wire around the toroid to get ~ 8V, a diode after, a cap and the led. The value of the cap controls the intensity of the led.
Old 18th February 2003, 01:06 AM   #7
Default I assume this is a shunt cap
Some have metioned a series resistor, you are using a shunt cap for filtering?
Old 20th February 2003, 05:53 PM   #8
Cap is for current limiting..... placed in series
Old 20th February 2003, 09:22 PM   #9
ElectroNick's Avatar
Beware of the orientation of the elko when placing it in series with a led !
Old 21st February 2003, 08:10 AM   #10
I put the cap after a rectifier diode, from the +V to ground. Then it is the blue led. I did it to get some ripple off the line voltage to the blue led. Now that I think of it maybe it is a silly idea, but it works. The bigger the cap the higher the voltage the blue led sees, that is why the cap is controlling the light intensity.
Power On Indicator Light pengboon Tubes / Valves 4 4th March 2008 10:31 PM
Gross power indicator Zero Cool Equipment & Tools 24 25th December 2007 06:32 AM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Anyone ever us a 6AF6G as a power indicator? Wardsweb Tubes / Valves 6 20th June 2003 12:08 PM
Page generated in 0.09875 seconds (80.99% PHP - 19.01% MySQL) with 10 queries
