IRFP9610 Heat Sink Aleph 2 Question (and others)
Old 16th February 2003, 07:56 AM   #1
TjongKristian is offline TjongKristian
Send a message via ICQ to TjongKristian
Default IRFP9610 Heat Sink Aleph 2 Question (and others)
I need some help in regard to the IRFP9610 heat sink. If you look at the pic below, heatsinks for the IRFP9610 are touching (Labelled 37 and 6). My question is there is a continuity between the two heatsinks with both "cooling tab"s (where you put the screw in), is it ok or it is a big no? Also, is it possible making a 10pf condensator with just a capacitance meter? THank you for your help in advance.
Old 16th February 2003, 11:11 AM   #2
bawang is offline bawang  Malaysia
You can always isolate the IRF9610 from the heatsink using the proper insulators (including the bushing for the screw!). This way, it doesn't matter if the heatsinks touch each other. I don't remember the circuit diagram, but if the center tabs of both MOSFETs are at the same potential (ie connected to the same point in the schematic), then you can leave out the insulation altogether which makes for a better heat transfer.
Old 16th February 2003, 02:02 PM   #3
harvardian is offline harvardian
Hi Kristian,
Nice build quality. Are those nylon sleeves on all of your components? Why did you raise them off the board? I like your heatsinks.
Best Regards,
Dale
doing my part to Keep Austin Wierd.
Old 16th February 2003, 02:42 PM   #4
Default Hi, Dale
They are clear heatshrink which fit most of the component's "leg." The reason I raise the component because I thought it looks neat and better performance due to the heat dissipation.
Old 16th February 2003, 03:54 PM   #5
grataku is offline grataku  United States
Default Re: Hi, Dale
It seems to me the only thing you should have insulated (9610), you haven't. The rest is pretty much useless.
Heat here is of no consequence, all you are doing is making it incredibly long to put the board together (which may prolong your enjoyment ), lenghtening the signal path, and making it impossible to probe voltages during testing.
Old 16th February 2003, 04:03 PM   #6
Hi Paolo (grataku),
I was thinking the exact same thing, but was afraid to write that down. I needed to check my voltages during testing. Would have been very difficult with heat tubing.
I have heard of raising some components off the board slightly to add a small space for air to flow. Slightly means barely visible...
Kristian, we are not trying to "dis" you, just trying to understand and help others.
Best Regards,
Dale
Old 16th February 2003, 04:37 PM   #7
Default Thank you for the info.
Bawang,
Thanks for the info, I will check the schematic for that.
Grataku,
Yes, Grataku, Indeed the heatshrink prolong my enjoyment . I try to anticipate the voltage measurement by either turning the board upside down or using the tip of my DMM's probe (the board is thruhole), it is quite cumbersome, but most important of all, I am enjoy looking at the neat board.
Dale,
I also would like to express my deepest gratitude to Brian and Dale for their effort which allows me (and others) to get a chance to hear one of the best amp that otherwise will be unaffordable (for me at least).
The only thing that I am afraid when the Aleph 2 is done that suddenly my preamp is not good enough, and then I realized my speaker is not giving me enough. The whole world starting to crumble in front of my eyes..........
Old 16th February 2003, 06:38 PM   #8
fcel is offline fcel  United States
TjongKristian,
Looking at your component installation reminds me that there is one area that I would like (but forgot to mention) BrianGT/Harvadian to incorporate into the board layout for the second batch of group buys ... and that is ... to have the component call out to be shown outside of the rectangular box (i.e. not directly below the components) ... just like the Aleph-X boards. No big deal but ...
Dale/Brian,
If there is going to be a third group buys (or is it fourth?), is this something that can be done easily?
Old 16th February 2003, 06:57 PM   #9
Hi Roderick,
Moving the reference designators is very easy. If not carefully done, it can lead to confusion. A trade off. The important thing is to try and be consistent (i.e. always below, or to the right, etc).
I just ordered more boards, but made no changes to them.
Dale
Old 16th February 2003, 08:15 PM   #10
Asen is offline Asen  Bulgaria
Send a message via MSN to Asen
Default Caps question
What caps does Mr. Pass use in the original ALEPHs? Black Gates?
IRFP9610 Heat Sink Aleph 2 Question (and others)Hide this!Advertise here!
Aleph P1.7 heat sink? sugano Pass Labs 1 11th July 2006 03:56 PM
Aleph X heat sink thread Peter Daniel Pass Labs 306 24th July 2003 01:17 PM
Aleph 2 Heat Sink (chassis) TjongKristian Pass Labs 32 21st December 2002 06:19 PM
Aleph 3 Heat sink capability raincheck Pass Labs 27 25th June 2002 04:14 AM
