Old 14th November 2007, 05:01 AM   #1
Default A75 front-end unwanted output signal
Hi All,
Can anyone help me about my A75 , it almost be completed but it response with square wave input would have a little spur signal in output waveform raising edge, out of this all is normal and well .
Actually, I do not use folded cascode (without R21 & C6) and the feedback resistor R81=700 ohm. When measuring the front-end output did not connect the power FET but have C8 and R31 connected to GND.
How can I vanish this unwanted signal and why it will happen ?
Analogy
Old 29th December 2007, 09:28 PM   #2
norb is offline norb  Germany
hi ckwong99,
i have attached a picture with a signal that i suppose is what you describe in you request.
If it is like this, there is no reason to be afraid, this is normal behaviour as the amp tries to adapt to the new voltage level of the signal as fast as possible. Since the amp is not indefintely fast - and no amp is - you will see this slight overshoot.
So enjoy your A75, it´s a great amp and a ear-opening experience.
Greetings
Norbert
HK 'Deuce front end on G2 drive output stage? GordonW Tubes / Valves 0 9th June 2008 02:22 PM
Yamaha RX-V650 AV Amp No Output From Front Right Speaker grannysmith Solid State 27 5th September 2006 01:18 AM
Elektor op-amp front-end with mosfet CF output stage Dusk Elektor 1 5th April 2006 04:09 AM
Hybrid tube front end and transistor output stage Original Burnedfingers Solid State 6 4th April 2004 11:28 PM
CDP output signal to high for P3A? sobazz Solid State 12 12th September 2003 10:02 PM
Page generated in 0.06230 seconds (68.92% PHP - 31.08% MySQL) with 11 queries
