In the Aleph 2, 4, 5, 30 and 60 schematics the negative feedback resistor value is 100k, but in the Aleph 3 schematic the value is 10k.
Is the Aleph 3 schematic ok? |
#2 |
Hi ,
Yes it is correct as the lower feedback limb is also reduced by a similar factor of ten, down to 1k (as opposed to 10k.) It is the ratio of these 2 resistors which sets the overall gain, and in one case it is 100k/10k, and in the other it is 10k/1k. One clear advantage of using higher overall values of resistance here is that the series cap in the lower limb can be reduced. This allows the use of a better performing (sonically) film cap instead of the much larger cap necessary with lower value resistors, which otherwise needs to be an electrolytic. Regards,
Bob |
#3 |
Thank you very much for your answer.
#4 |
Pas un probleme.
Bob |
| Marantz CD63 KI SIG, Error 12, Sled Error problem | sisik | Digital Source | 1 | 9th November 2008 03:12 PM |
| Simple 45/2A3 schematic error? | Richard Ellis | Tubes / Valves | 1 | 14th April 2008 03:24 AM |
| Error in power amplifier schematic | routhun | Solid State | 20 | 26th December 2006 10:17 AM |
| Whats worse, 1db error in response curve or a phase error of 6? | primalsea | Multi-Way | 5 | 13th May 2003 01:24 AM |
| Possible error in Aleph 5 diagram!? | hifi | Pass Labs | 2 | 11th April 2001 09:04 PM |
| Page generated in 0.07285 seconds (76.74% PHP - 23.26% MySQL) with 10 queries |
