Old 15th February 2003, 06:34 AM   #1
louischia's Avatar
Question which brand n model for Aleph2 10pf mica?
hi all
which brand do u guys prefer to use for the Aleph2 10pf mica caps?
Cornell Dubilier mica capacitors?
http://www.cornell-dubilier.com/mica/framemica.htm
or other recomendations?
wat about model?
if Cornell Dubilier which model do u guys think will best suit tat job most?
i plan to get the best available
thanks all
Louis
new kid on the board!
Old 15th February 2003, 02:35 PM   #2
Default Silver Mica Caps
All the CDE mica caps I have found have plated steel leads. The best sonically use non-magnetic lead material.
I am not sure if non-magnetic silver mica caps are still manufactured. But take a magnet to the parts store and check.
The last ones I found were the real small sm caps. I think they were 500v and 10 pfd. These were the smallest at the local store.
One way to check without a magnet is the flexibility of the leads. The tinned copper and much softer and flexible than the tinned steel.
Reading the info that comes with the CDE caps makes me think they would be fantastic if another material was used for the leads.
George
Old 15th February 2003, 02:58 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: which brand n model for Aleph2 10pf mica?
Louis
If you plan to get the best avilable, install nothing. I just removed the silver micas from my Aleph X and the sound improved.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 15th February 2003, 03:11 PM   #4
grataku is offline grataku  United States
Default Re: Re: which brand n model for Aleph2 10pf mica?
How so?
Old 15th February 2003, 03:18 PM   #5
You know, I've been tweaking my Aleph X recently and I do whatever possible to match the sound to my gainclone (this is a joke, of course), so I removed those caps yesterday. The sound became more open, with more direct vocal and better detail. I also installed some S102 Vishay resistors.
It's not really important to me if square wave will be perfect on a scope with those caps, if sonics suffer. Probably the best cap for that location would be one made of a pair of twisted insulated wire, as Nelson described in Aleph X thread. I might try it too.
www.audiosector.com
Old 15th February 2003, 05:30 PM   #6
Bobken is offline Bobken  United Kingdom
Default Re: Silver Mica Caps
George
If you are interested, TAB in the UK still makes very good-sounding non-magnetic silver micas, and they are much better in performance than the usual magnetic ones.
When I was last in contact with TAB, they had apparently had some enquiries from the USA, although I don't know from whom.
TAB will not supply direct in small quantities, unfortunately, but if you are after quite a lot, its worth contacting them.
Otherwise, if it helps, Erno Borbely in Germany stocks these caps now, and they can be found on his webpage.
Bob
Old 16th February 2003, 12:29 PM   #7
louischia's Avatar
Thanks alot everyone
i think i'll try wifout any caps 1st den search fr some non-magnetic silver micas locally or mayb try twisting some wires
Louis
Old 16th February 2003, 04:12 PM   #8
Louis
In this case, I believe that some excellent non-magnetic silver-mica caps made by 'Soshin' in Japan, might be easier for you get hold of. By repute, they are even better sonically than the TABs, but I have not (yet!) tried them, myself.
Bob
Old 8th February 2004, 10:14 PM   #9
Hi Peter Daniel,
I searched the complete 170 pages of alephx thread, but doesn't find Nelson Pass description of "twisted pair compensation caps" as you wrote some posts earlier in this thread. Would be a good thing for me, as silver micas are not so easy to trace here.
micha
Old 9th February 2004, 12:54 AM   #10
Here it is in a response to a question on the Zen 4.
http://www.diyaudio.com/forums/showt...295#post224295
Looking for info onan unknown Tweeter model (M&K brand)? JBCon Multi-Way 0 8th December 2008 06:08 PM
Best Brand/model CD-rom for various DIY controllers dnewma04 Digital Source 1 7th August 2008 10:12 AM
I got driver from germany. can u tell me what brand and model is it? jinkuchi Multi-Way 3 10th September 2005 05:43 PM
what brand and model of speakers are in the definitive tech bp 10 zuki Multi-Way 6 4th August 2004 11:40 PM
Which caps for aleph2's? (10pF and 1nF) cowanrg Pass Labs 5 2nd October 2002 12:27 PM
Page generated in 0.10866 seconds (79.23% PHP - 20.77% MySQL) with 10 queries
