I am happy,
I have success my blocks Aleph 2. but I have a question. If one 240 dies, I afraid of the D.C. current in the HP . 1----- know you are a means of protection? I find that the blocks are very hot. my heatsinks are large 350x200x40. 2----- should ventilators be put?
stay zen |
#2 |
stay happy!
As long as you can touch the heatsinks you are ok! Don't worry, the Alephs are industrial designs, and they generally don't ever break!
Mads K |
#3 |
Mads K |
#4 |
The one and only
Even if you pop an output, it's very rare to see
speaker damage as long as you fuse the AC line at a reasonable level. |
#5 | |
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#6 | |
#7 | |
diyAudio Moderator Emeritus
I guess I will have to be more careful when I finish my Aleph amplifiers... -- Brian |
#8 |
top and bottom are not glued on yet and are just sitting on top and bottom to show the finished size.
I got my cardas binding posts from Rodd, which will be going where the holes are where the 12ga wire is coming out of now. -- Brian |
#9 |
Try building one of the many designs for loudspeaker DC protection available in the market. I am using ESP's (Rod Elliott) design with great success, and it does not need a dedicated DC supply!
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Questions about the Tang Band W8Q-1071F 8"x12" Subwoofer | MyNameIsJake | Subwoofers | 4 | 26th January 2008 02:57 AM |
| "Quasi" ultralinear experiment - questions... | Eusebius | Tubes / Valves | 8 | 11th July 2006 02:32 AM |
| ascendant audio "assassin" questions | peteS | Subwoofers | 4 | 9th March 2006 05:15 PM |
| Aleph "L" Stepped attenuator on the input or the output? | Mark A. Gulbrandsen | Pass Labs | 6 | 13th March 2003 12:21 AM |
| Page generated in 0.10672 seconds (76.50% PHP - 23.50% MySQL) with 11 queries |
