PCB help Aleph P
PCB help Aleph P
Old 7th November 2007, 09:22 PM   #1
loovet is offline loovet  Sweden
Default PCB help Aleph P
Sad but true, Iím still working on my first electronic project ever which I started in 2002. Okay, I know that my pre is working but I still havenít got a chance to finish it, and I donít know if I ever will. At least with the tempo I have and with all opportunities there is today with LCD screens and every thing. Tough I have now decided to at least get my pre in to a home made chassi, which is more or less finished.
I could have started with an easier project, but what doesnít kill you will make you stronger. And believe it or not I have my volume control with a PIC up and running.
Five years ago I started to draw in the PCB layout and I also got it up und running. But today when I look at my old PCBís they doesnít look that nice I have to admit, and they are too big to get in to the chassi Iíve built (normal size). So now I am working on a new layout and I have to admit that I have been looking quite a lot on the design that veteran made a group buy on. But this one is double sided and I will be using Black Gate N capacitors for my pre.
I would really appreciate if you could give me some comments on the layout. I have not made the fine tuning of the traces yet so pls see it as a draft.
When I have finished the layout I will be happy to share it with all you guys how have made my project possible, especially Nelson him self.
Thanks in advance
/loovet
Old 7th November 2007, 09:26 PM   #2
Default 3D
And as you can see on the layout in 3D I have added space for an aluminium bar so that the transistors will work at the same temperature.
/loovet
Old 8th November 2007, 07:15 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
Hi loovet!
I'm myself pretty new to pcb-layout, so please take my advice with a grain of salt.
While the parts are layouted symmetrically, the traces aren't. This won't mean the layout won't work, but it's not elegant. If you're ambitious to draw optimum traces, I would say there's in a symmetrical design only one way, not two; thus a symmetrical schematic should yield also a symmetrical layout.
Further I will need a far wider ground trace which will be problematic due to pad spacings. There's enough space to move the parts a bit apart.
Next I see some traces crossing the pads of the big caps which does not seem to be your intention, so this would give a connection problem? Further you fork a trace in the middle of the left big cap which is also not optimal since it's not the shortest path possible (the forked trace runs in parallel for quite some time).
At C9 I see a trace that seems to go nowhere?
I'm sure you will get a nice layout!
All the best and have fun! Hannes
High Octane phono preamp Wiki
Old 9th November 2007, 10:35 PM   #4
h_a thanks for the input.
I've done som changes to the layout;
- I've tried to make it as symmetrical as possible
- I've made a wider ground trace
- I've made a Star ground (at least as much as possible)
Pls feel free to add your comments.
BR
/loovet
BTW one of the pads on the left capacitor is a dummy, and want affect the circuit
Old 12th November 2007, 11:25 AM   #5
Should I take the silence in this thread as a clear to go or
BR
/loovet
Old 28th November 2007, 12:55 PM   #6
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
well......good job!
it just need some final adjustments but very nice indeed.
Have fun.
PS: i'm building the same pre and this week i'm going to burn the board that i have put aside the past 3 weeks due to other things to do.
Stefano
Old 27th March 2008, 09:22 PM   #7
A picture of the final PCB's...
BR
/loovet
Old 27th March 2008, 11:25 PM   #8
Stefanoo's Avatar
Nice!
have you tried it out yet?
what kind of volume control are you going to use?
Output vol or input?
Have you checked the noise on the tweeter?
This design is inclined to give you a little hiss on the tweeter, but if you properly ground it and distribute the gain of the stage and the output potentiometer's value you can get it pretty much dead silent.
keep us update.
Best.
Stefano.
Stefano
Old 1st May 2008, 01:48 PM   #9
Hi Sefanno,
I've tried it out and it works. But so far I've only been able to try it out with an Ipod and my headphones, but never the less it works.
I will use this volume control and it will be on the output...
http://www.diyaudio.com/forums/showt...hreadid=102272
Attached a picture of the stuffed board ;-)
BR
/loovet
PCB help Aleph PHide this!Advertise here!
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 20 7th April 2018 11:04 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 27 11th November 2017 01:13 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
