#11 |
Banned
The Zen Lite should be used with the High / Low Pass http://www.diyaudio.com/forums/showt...394#post155394
driving TAD2001 with my horns http://www.diyaudio.com/forums/showt...6329#post96329 Iīm still not sure about the schematic. I donīt want to build it exactly like the original Zen Lite. I donīt have a large 4mH inductor, i donīt want a turn on thump protection circuit. I donīt need low frequency from the amp as the TD2001 should be used above something between 500 and 1000Hz. So i think some capacitors could be smaller -- what means i can use higher quality (film instead of elko) I donīt have ZVP3310 so i have to use IRFP9610. The amp will have no powersupply - only a connector for an external powersupply 2m away. Mr. Pass, could you please critically comment this schematic? |
#12 |
Banned
Box is ready, but still not sure about values in the circuit. (see above)
#13 | |
Banned
I have it running, but without the 9610 yet.
One more question: from the article Quote:
#14 |
Hi Till,
what about the regulator in the ZenV3 variations? Take Fig2 and make C1 bigger and you should have a delay you can modify to your needs. I once used this as slow turn on PSU for headphone amp. It just wonīt help you with turn-off-thumps. Regards Jens |
#15 |
Banned
Yes, this was what i thought of. But turn off thumb? if i turn off it goes slowly silent and distorted but no thumb.
#16 | |
Marcello who scaled the Zen amp for the use with headphones experienced a turn off thump and recommended a circuit that shorts the ouput during startup and switch off as well to avoid that. In that case the regulator of the ZenV3 wouldnīt be sufficient. But I think Iīll try anyway ;-) Cheers Jens |
#17 |
The one and only
You are going to have some difficulty with this circuit with R1
looking at the top of the light bulb. R1 and R2 are there to set the DC operating point for the Mosfet, but to do this they need to see the Drain voltage of the Mosfet, and your circuit only gives the supply. At the very least, make R2 a potentiometer. Note that the impedance of R1 and R2 are quite high compared to the source impedance. As such, they don't contribute much in the way of feedback at AC frequencies - they simply set the bias point. |
#18 |
Banned
Thank You very much. If i connect R1 to drain, shall i make R2 a potentiometer too? Should it be adjusted to 1/2 V+ at drain or to 15V?
Is the circuit diagram right so? Would values for C1 and C2 be ok in case the amp is used as high frequency amp for TD2001 and driven by the coming High / Low Pass Xover or do they need to be larger? V+ is only 35V at the moment because my bench supply donīt delivers more. I think a final PS will be 45 - 50 V so. |
#19 |
Banned
hopefully corrected:
#20 |
Banned
with 32V i have 2,3 A for both channels. So a larger powersupply with 45V may be better. Unfortunaly after 48 hours dissicipating heat with the bulbs the wood under the bulbs got a crack. I think it was not dry enough. I have to replace it.
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Capacitor Question /question on cap | TunaFish | Tubes / Valves | 14 | 12th January 2004 02:23 AM |
| PS question - tformer question actually | breguetphile | Chip Amps | 2 | 30th May 2003 01:29 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.11183 seconds (79.64% PHP - 20.36% MySQL) with 11 queries |
