Aleph J Schematic
Aleph J Schematic
Old 23rd February 2013, 03:10 PM   #1551
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I may when time comes. Too far in the hole to worry about now. I may not do it and just keep it as part of SE rig. It is the killing of the sweetness that I am not excited about, as that is the reason for it in the first place.
I do have question. I think 6v6 pre has about 15dB of gain. I should only need 10 more, max for Altec rig, correct.
...Shape the sound , Man!
Old 23rd February 2013, 03:14 PM   #1552
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Aleph J Schematic
and the question is ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st March 2013, 04:32 PM   #1553
schultzsch is offline schultzsch  Europe
removed C3 from the game just from curiosity
for the quiet nights I`m thinkinig to use a switch and a 2x10cm wire to interrupt C3R24 network.would there be any sound degrading or possible oscillation apearance? from the wire/switch part
Old 1st March 2013, 06:50 PM   #1554
Zen Mod's Avatar
Aleph J Schematic
instead of switching out/in of C3 , proper SE operation can be with switch across R20-R23 group
that way - there is no more CCS modulation and these resistors are no more in series with speaker output
Old 1st March 2013, 07:07 PM   #1555
and C3 remains connected?
Old 1st March 2013, 07:17 PM   #1556
Zen Mod's Avatar
Aleph J Schematic
yup
Old 1st March 2013, 07:23 PM   #1557
wil try
btw managed to mount that timmer, you gave me the schematic for , in the tube preamp and works nice, now I turn on confidently my amps
Old 1st March 2013, 07:28 PM   #1558
Zen Mod's Avatar
Aleph J Schematic
Old 5th March 2013, 12:05 AM   #1559
francolargo is offline francolargo  United States
Originally Posted by sakellogg View Post
r27 as a pot to jack up the bias. more bias makes it sound better. but adds heat.
OK! My plain A-J boards check out, which is a relief! I tested a SE signal into each side of each board using a junk speaker and first impressions are favorable. One side measured 8.73 V across R8 rather than 8.3... That board seems to have a bit more gain and a little less control than the one that measures 8.3... Thoughts?
So, I'm planning to remove R27 and install multi-turn trimmer pots. Question: does increasing the resistance at R27 increase or decrease the bias?
TIA,
Frank
Old 5th March 2013, 04:53 PM   #1560
Answer to my own question: I don't have much thermal headroom to raise the bias anyway, so the R27 pots are sitting at 64k. With that amount of current, the temperature rise is ~32 degrees above ambient with silent airflow, 27 degrees with the fan 'barely noticeable', and 24-25 degrees with the fan at full speed of 1200rpm. If you are curious, images are the air tunnel, the front panel fan control with thermal readout, and the profile of the air exhaust. The power supplies have 75 degree thermal cutoff switches on the heatsinks.
Frank
Aleph J SchematicHide this!Advertise here!
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright ©1999-2017 diyAudio
