Aleph J Schematic
Aleph J Schematic
Old 10th January 2013, 09:31 PM   #1441
schultzsch is online now schultzsch  Europe
Old 10th January 2013, 09:52 PM   #1442
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Aleph J Schematic
Originally Posted by schultzsch View Post
put relay contacts as normaly closed switch between pre out and gnd
you can put some 47R-470R in series with switch
you can use heater supply for timer
if heater supply is in range of 6V , use 6V relay
if 12, then 12
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th January 2013, 10:48 PM   #1443
I`ll take this as 1`st priority
As always... ty!
Old 10th January 2013, 11:02 PM   #1444
I have at hand some axicom 5V smd relays but I would like to use a schematic that uses relay normal open circuit so the coil work only for 1 minute. is it posible only with transistors?
Old 10th January 2013, 11:07 PM   #1445
Zen Mod's Avatar
Aleph J Schematic
relay must be closed while preamp is off , so you must use normaly-ON contacts
when you power it - timer is counting , then energizing relay to remove muting
use sch No.3 -short instead of pictured S1-so it will start counting right after power is applied
so - now you have know-how ....... just use plain simple logic ...... and make it
Old 10th January 2013, 11:20 PM   #1446
yes...you are right but the relays aren`t audio type and they aren`t screened neither as for this I would like to use a counter fom 0 to 60 that after this period would stop power on the relay.as saying earlier would like to use normal open circuit so when i power on this closes, shorts output for one minute and after this removes power from relay.thought about this because I don`t want any magnetic fields near audio signal wires, conectors, if this issue isn`t a problem I will use sch. no 3
Old 10th January 2013, 11:22 PM   #1447
Zen Mod's Avatar
Aleph J Schematic
frankly - I'm tired ;
make it or not - your choice
been there , done that , gave you advice
Old 10th January 2013, 11:28 PM   #1448
one way or another I`ll do it, still remained 1`st priority
wish you a good night!
Old 12th January 2013, 09:16 PM   #1449
started at 9am finished at 9pm and there still is work to do ...
Old 15th January 2013, 09:27 PM   #1450
is there any problem if I solder the power resistors to the copper bars with these atached to the caps?
Aleph J SchematicHide this!Advertise here!
aleph 30 schematic kendt Pass Labs 17 24th March 2012 02:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 01:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 09:49 PM
Copyright ©1999-2017 diyAudio
