Aleph J Schematic
Aleph J Schematic
Old 29th November 2012, 04:17 AM   #1321
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Originally Posted by craigtone View Post
19 years of PCB design here. I'd love to help and ironically enough I was planning to build an Aleph J this winter ...
I have the Aleph J schematic if someone can educate me on "Universal Mounting Spec", I can start tomorrow.
http://www.diyaudio.com/forums/image...ation-v2.1.pdf
Old 29th November 2012, 04:48 AM   #1322
6L6 is offline 6L6  United States
6L6's Avatar
Aleph J Schematic
Thanks for the link, you beat me to it.
As for the board, I was envisioning the same basic layout as the F4, F5c, etc... The longer board with the outputs all on the lower edge.
Also, I would love to see R7 replaced with a trimmer pot, as that's where you will be able to dial out any DC offset on the outputs... Maybe put pads for a parallel resistor there as well...
J109's are basically impossible to get anymore, so most people will be using a matched pair of J74's... it would be handy if they were face to face so their cases can be zip-tied together for better thermal tracking.
Thanks a bazillion for the offer!
Old 29th November 2012, 08:14 AM   #1323
kroyin is offline kroyin  India
Ok i fell flat with the second channel
Offset is (-)23.6Vdc
R7 - 36V
Q3 Vce-36V
Q2 Vce - 0V
Q4 Vce ~ 4 V
Z1 - 9.9V
R8 - 9.1V
All source resistors are around ~.56xV
Q5 & Q6 gets pretty hot (case temp of 70C after 5 mins)
So before i unmount the setup, anything that comes to anybodys minds pls.
I have used 2Sj74 & BC550/560 (have been careful with the pinouts )
Old 29th November 2012, 11:40 AM   #1324
derwhalfisch is offline derwhalfisch  New Zealand
Can I jump in and suggest right now, please fellers, that a new thread is opened for discussion of a new UMS Aleph J board design rather than doing it in here?
I'm interested in following if not contributing to the process and I think it would be a mistake to bury something that important in the 13?th page of an existing thread.
Much respect to craigtone for bravely volunteering ;P and all due respect to 6L6, and Mr dB.
Old 29th November 2012, 12:09 PM   #1325
R7 - 36V
Q3 Vce-36V
Q2 Vce - 0V
Q4 Vce ~ 4 V
Z1 - 9.9V
R8 - 9.1V
I dug up a old post from Zen it says
'so - voltage across R7 is completely dependent on input LTP's CCS (Z1, Q2,R8)'
So as of now Q2 seems to be the culprit as R8 & Z1 reads more or less ok
Old 29th November 2012, 01:25 PM   #1326
Jay is offline Jay  Indonesia
Banned
Default What is your power supply Zen Mod?
I use your bablefish variation. 24V-25V seems optimum. So 28Vdc transformer with the standard Zen mosfet pre-regulator to lower the voltage to optimum value. What PS do you guys use? What is best?
Old 29th November 2012, 03:37 PM   #1327
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Aleph J Schematic
whatever you have , between +/-18 and +/-28Vdc
be sure that steady dissipation of each IRFP150 is no more than 50W , with proper heatsinking
Pa sez that input Jfets (in that configuration) are pretty safe up to ....... +/-35Vdc PSU , if I remember correctly
whatever - I don't like regs in power amp supply , for my taste better solution will be to un-wind some turns of xformer secondary , if possible
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th November 2012, 10:41 PM   #1328
Banned
Okay thanks ZM. I will use 18Vdc EI transformer then. The 28Vdc toroid for another amp.
Old 2nd December 2012, 05:42 AM   #1329
Default pls help
Change q2,q3,q4 but things are not right
ZD1-9.36V
R8-8.75V
Q2 Vce-13.8V
Q2 Vbe- 0.6V
R7-8.7V ?????
R16,17,18,19- 0.59xV
Q5,Q6 Vgs - 4.2V
Q7,Q8 Vgs- 8.1V ???
Q4 Vce-4.68V
One other thing the good channel has 0v across 5pF, while the bad one has 2.8v
I am confused
Old 2nd December 2012, 07:36 AM   #1330
I don't think the input JFets are blown since Q2 readings are same across both the channels...but I think the problem starts with R4 (bad channel 27v good channel 0V) which again point to JFET
Aleph J SchematicHide this!Advertise here!
aleph 30 schematic kendt Pass Labs 17 24th March 2012 02:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 01:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 09:49 PM
Copyright ©1999-2017 diyAudio
