Aleph J Schematic
Aleph J Schematic
Old 10th November 2007, 12:15 PM   #121
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Aleph J Schematic
Originally posted by EUVL
> even 27 can be fine ;
You probably have not been listening to Mr. Curl on the Blowtorch thread.
Whether the JFET will blow at 27V is one thing, whether it still operates properly is another.
Patrick
EUVL , gimme a break ;
if it works on 24 , it will work even on 27 ...... but you must always count on +10% in mains voltage . that is where is real danger , not in squible about tiny fraction of lesser performance;
if I must pay price as usual to collect knowledge in mentioned thread... that always leave bad taste in my mouth .
man can resort on L input filter if xformer in case is on high side , voltage wise .
or burn few volts in R part of CRC filter
whatever
if you wanna comment something - ask Papa why he isn't cascoded little critters
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th November 2007, 12:26 PM   #122
EUVL is offline EUVL  Europe
> gimme a break ;
I gave you a hint.
Please feel free to decide whether to do anything with it.
Patrick
Old 10th November 2007, 12:46 PM   #123
B.L. is offline B.L.  Poland
B.L.'s Avatar
My Aleph J - modified A5 PCB.
Old 10th November 2007, 01:01 PM   #124
traw is offline traw  United States
Repeat of question is post 127. Any notable difference taking the usual 'fine tune dc bias' adjust resistor (68k) after the two resistors to base rather than from in between the two resistors (1.5 & 3.32)?
Old 10th November 2007, 05:19 PM   #125
hifimaker is offline hifimaker  United States
hifimaker's Avatar
This type of horizontal layout is really nice.
One thought, could the distance between the 2 output sections of MOSFETs be increased to better take advantage of the heatsink? Having the actual dimensions of this board would be helpful to judge.
Having space for the 2 additional output MOSFETs is a nice option for higher biased version.
In both board designs above it's great to see the input and output sections on one board rather than 3.
Just my $.02 worth.
Nice work guys.
-David
Old 10th November 2007, 06:50 PM   #126
GRollins is offline GRollins  United States
I must say that I'm not a big fan of running semiconductors at their rated limits, much less over.
Grey
Old 10th November 2007, 07:03 PM   #127
Zen Mod's Avatar
Aleph J Schematic
Grey
me too .......... but that was not a question .........
that's same as using gas toob at max current .
looking in devils eye
Old 10th November 2007, 07:17 PM   #128
hifimaker's Avatar
Wouldn't the additional mosfet's spread the load across more parts? I'd like to bias the amp to produce full power into 4 ohms rather than 8.
-David
Old 10th November 2007, 08:30 PM   #129
B.L.'s Avatar
Isn't distance between output sections enough?
Old 10th November 2007, 08:53 PM   #130
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I have some pcbs for babelfish they are 22cm long and have C/C 5 cm between the fets.5 cm seems allright.
How long is your bord?
And where to find a schema for A5?
Hope you do some series making of those boards later..
Regards ke
Aleph J SchematicHide this!Advertise here!
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright ©1999-2017 diyAudio
