Aleph J Schematic - Page 24 - diyAudio
Old 20th November 2007, 07:54 PM   #231
EUVL is offline EUVL  Europe
> One could use a separate, more negative supply on the 'J109's drain R, maybe just hooked off with a zener or TL431...
Doesn't any ripple voltage (or noise) between this "more negative supply" and the "normal" negative rail gets directly magnified in the 2nd stage, i.e. 0dB PSRR ?
Patrick
Old 20th November 2007, 08:11 PM   #232
KSTR is offline KSTR  Germany
KSTR's Avatar
Yes... so the dropped supply must be very clean. I think a shunt reg, properly bypassed to R18/19, would do it. With adjustable offsetting one could also optimize the LTP current and output offset independently, even open-loop gain (via R7). Not shure if this would still be an Aleph-J, though.
- Klaus
Old 20th November 2007, 08:32 PM   #233
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
another brilliant idea
EDIT :
I forgot that I need P type LU for that
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th November 2007, 09:03 PM   #234
very interesting and very promising so far.
keep it up.
SandMarc
Old 20th November 2007, 09:13 PM   #235
Zen Mod's Avatar
keep it up.
SandMarc
yup-as follower .........
Old 21st November 2007, 05:28 AM   #236
I am stupid this morning.
Explain to me how you might get +1V Vgs on your P-type LU (or if you flip it, then -1V Vgs on LU1014) to get the triode curve ?
> keep it up.
It is perhaps time you get your own brain to do some work ......
Patrick
Old 21st November 2007, 07:57 AM   #237
Zen Mod's Avatar
> keep it up.
Patrick
Patrick
I know that you are stupid , so there is no need to say that in public ;
for me - name of the game is fun , not "smartyfarty" ;
I'm not here for contest .
you are looking at trivia in that schmtc , even if entire schmtc is trivial
Old 21st November 2007, 08:02 AM   #238
I have no problem admitting that in public.
Neither am I.
It was a legitimate question.
The entire difficulty of using LU1014 in the circuit IS the negative Vgs.
I had a second look just now and still could not figure out how your proposal would solve that.
So perhaps you can enlighten me.
Patrick
Old 21st November 2007, 10:35 AM   #239
Zen Mod's Avatar
Neither am I.
so - welcome to the club of smart ones , so we can continue with fun......
Patrick
it was legitimate question , but it was also more than obvious that I made mistake connecting G-S of LU ( that line probably was just intention to draw bracket for pointing voltage G-S , or just brain glitch ..... whatever )
input LTP is nothing else than tube LTP and LU is nothing else than top tube in output tube cascode ........biasing LU is achieved with biasing input LTP ......... pretty common way of DC coupling two stages in tube world ........
anyway - nothing of that is important really ; what is - is that I drew follower with LU , not active stage ......
it can be done like this , but with full swing stage in middle , and I don't wanna do that.
Old 21st November 2007, 11:42 AM   #240
Choky,
I think you are still missing my point.
Put the +ve rail on the bottom, and you almost get back to Nelson's schematics.
The voltage across the drain resistor of the diff pair is something like 4V ABOVE negative rail. If we stick to a source resistor of 0R68 for the LU1014, AND you want it to work in the triode region, then the current through the 0R68 is something like (4+1)V/0R68 = 7.3A. That is likely to kill your 1014.
In ZV9, the gate of the 1014 is at 0V nomimal. But because there is a bias of about 1.3A, the 0R68 will have 1V drop across it, makeing the source at 1V nominal. Thus, Vgs is about -1V.
Any modification of the A-J schematic to use the 1014 has to be able to offer this -1V Vgs before it will work as intended. My proposed solution with the 4mA CCS diode is intended to drain all the DC current of the diff pair so that there is no DC current across the drain resistors, i.e. Vg at negative rail voltage. The rest is then like ZV9, but referenced to the negative rail.
Hope we are still not talking over each other.
Patrick
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright 1999-2017 diyAudio
