Aleph J Schematic - Page 22 - diyAudio
Old 19th November 2007, 03:33 PM   #211
KSTR is offline KSTR  Germany
KSTR's Avatar
I have to correct myself... EU mains voltage is 230V+-10% from 2008, not 230V+-15% (but I remember this value to be used as a design goal). +-10% is still a lot, 207V...253V. And it's RMS, not peak, but the latter is dominant for the PSU, at least under low load conditions (hence not much of a problem with class A).
It all comes from the EU-wide change to canonical 400V tri-phase... which poses a lot of problems with smaller tri-phase motors designed for 380V. These are likely to overheat and burn, because they are designed to run near saturation.
There is funny stuff in jacco's second link:
"The mains voltage has a surprising effect on the performance of a CD player. The motor speed is voltage controlled not frequency controlled with a crystal reference as most people would expect.
Even though the motor supply voltage is regulated, the mains voltage does affect it, making it play slightly faster or slower.
The effect on the music is quite large, making it sound either fast and exciting or slow and relaxed. I discovered this whilst experimenting to find out why a ‘Pandora’ isolating transformer, that was claimed to improve CD sound quality, did affect the sound. I discovered that the ‘Pandora’ was simply increasing the mains voltage by 24 volts, hence increasing the play speed and making the sound appear more ‘exciting’."
Oouuchh! is all I can say to that "expert statement"...
Back to Topic, and back to TickTock's question:
The "X-factor" is not the relevant aspect in the context of the power supply... rather it's the fact that this will be a bridged class A output stage. Only these draw constant current from the supply and need the PSU ground connection only as a reference point, with no load current flowing. In contrast, a non-bridged stage also draws a constant current, but only in an overall sense, not on the individual supply rails (at least these see only true reflected load currents, not the nasty half-wave rectified load currents as in class AB). Needless to say I'm a big fan of bridged class A...
- Klaus
Old 19th November 2007, 04:01 PM   #212
I was thinking about building the output stage with Lu1014Ds cascoded with the IRFP240s. Im my little world with limited understanding, this should be what dreams are made of...
SandMarc
Old 19th November 2007, 05:58 PM   #213
EUVL is offline EUVL  Europe
LU1014 cascoded needs 0V on the gate when used with a source resistor of about 0.68 ohm. IRFP240 as used in the A-J schematics has a corresponding gate voltage of about 4.5V. Not really a drop-in, shall we say ?
Patrick
Old 20th November 2007, 07:00 AM   #214
Lucas_G is offline Lucas_G  Netherlands
Default Alep 2 with Aleph J combined?
Hi J-builders,
Maybe this has been discussed somewhere, but i could not find it.
Has anyone designed an Aleph 2 with the Aleph J input?
I would like the 100 Watt power of the Aleph 2, but I would also like the improved sonics of the Aleph J. How can this be done?
Lucas
Old 20th November 2007, 07:24 AM   #215
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Not, unless you're willing to skip the 2-stage feature.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 20th November 2007, 07:41 AM   #216
Understood.
But can one build a more powerful version (60 to 100 Watt)?
Old 20th November 2007, 07:43 AM   #217
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: Alep 2 with Aleph J combined?
Hi J-builders,
Lucas
that means in Jaccovitty slang ............ that you need cascodes on jfet's bottom ( to save them of excessive voltage) and nice follower stage to achieve enough current for driving all these hungry gates in output
hmmmm - Papa will probably call that follower just 1/2 of stage
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 20th November 2007, 07:46 AM   #218
LU1014 cascoded needs 0V on the gate when used with a source resistor of about 0.68 ohm. IRFP240 as used in the A-J schematics has a corresponding gate voltage of about 4.5V. Not really a drop-in, shall we say ? <
Of course not. ( Not that limited understanding ). By posting I hoped that someone would maybe come up with a clever way around it. Coupling caps or whatever.
SandMarc
Old 20th November 2007, 07:55 AM   #219
Zen Mod's Avatar
SandMarc
with caps is hard to maintain DC offset
I'll try to be smart....... but someone will be faster, certainly........
Old 20th November 2007, 11:01 AM   #220
One possible solution is, for example, you can put a 4V5 10W Zener Diode below the source resistor.
Not that this is the best solution with the least distortion......
Oh, another one :
Hang a 4mA constant current diode (e.g. J511) from each of the drains of the JFET diff pair to 10V below the negative rail.
The rest I should leave as mental jogging exercises.
Patrick
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright ©1999-2017 diyAudio
