Old 15th November 2007, 08:44 PM   #191
hifimaker's Avatar
Just a couple of suggestions for the PCB.
Move the 3 resistors circled in red farther away from the solder pads they cross, similar to the same resistor at the top right.
See the suggested layout for the LED and resistor placement change made in this mock-up.
-David
Old 15th November 2007, 09:20 PM   #192
Holger Barske's Avatar
Thx Dave for taking care.
Done as you proposed, and added that "if you want to, you can add a trim pot to R8 / R27 and, after fiddling out the correct value, you may replace it with a fixed R; if you don't care at all, just solder those yellow jumpers"-feature:
Best regards: Holger
www.holgerbarske.com - Deutschsprachiges Paradise-Support-Forum
Old 15th November 2007, 10:44 PM   #193
hifimaker's Avatar
Hi Holger,
Nice work so far. Of course we have to have the "Steeno" multi-cap option for C1, that was recently added.
Could we see a version without the silk screen or components in place? It would be nice to see the gaps between the traces and pads.
One other thought is to move the V+ slightly to the left for more clearance.
-David
Old 15th November 2007, 11:41 PM   #194
Dave,
here ya go: http://www.hb001.de/alephjpcbbottom_rc8.pdf
Drill sizes minmized, easier for homemade pcbs.
Clearance is above 8 mil everywhere, this is what most board houses ask.
Not a good idea. Need some space for the pcb mounting studs around the corner holes. Moving the pad to the left might cause a short between V+ and the grounded chassis.
Old 16th November 2007, 09:21 AM   #195
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Mit der jeder das tun kann, was er will
An additional Lochchen under R4 would be nice to allow for 10mm specimens.
(provided you're not sending Christian to Buerklin to get some 6mm 0.6W/TK25 Yageo's)
For DIY picoFarad squeezers :LC
Not so much,.......if it says "ZM" in the corner.
Old 16th November 2007, 09:59 AM   #196
ticktock's Avatar
Hi Zen,
signature isn't complete, but, of course, there's no EMT in the system
at the moment.
Had a nice pair of naked TSDs here til April.
Looking for TU2/TU3 now...
ps: welcome to analog-forum !!
Old 16th November 2007, 06:15 PM   #197
chinsettawong's Avatar
Hello!
I notice that there will be 4 mosfets per channel in this set up. Do these mosfets need to be matched?
Wachara C.
Old 16th November 2007, 06:40 PM   #198
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by chinsettawong
Hello!
Wachara C.
yup:
upper two are pair
lower two are pair
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 18th November 2007, 03:56 AM   #199
ticktock's Avatar
Hello DIYers,
what's the proper rating for the transformer?
300 VA ?? Will 500 VA be harmful ??
Old 18th November 2007, 04:18 AM   #200
Formerly "jh6you". R.I.P.
Babowana's Avatar
Yes, but harmful only for your money pocket.
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright ©1999-2013 diyAudio
