Aleph J Schematic - Page 176 - diyAudio
Old 1st September 2013, 07:00 PM   #1751
Danger Mouse's Avatar
Originally Posted by wengtech View Post
i hope this will help eliminates your hum (at lest reduce )
Attachment 368804
i am doing this wiring to all my monster...
Thanks for your help
Problem is solved i moving back to the layouts from the aleph wiki.
And going with all groundwires to starground between the last PSU caps.
Now all is hum free.
But was a lot of work.
Changed to much at the same time, maybe the PCBs was the error or the
groundrouting. who knows
Old 1st September 2013, 07:12 PM   #1752
Originally Posted by 6L6 View Post
The BA-3 front end is zero feedback..
yes you are right but it is se or pp ?
Old 1st September 2013, 07:25 PM   #1753
BA3 looks like PP
Old 1st December 2013, 10:37 AM   #1754
one channel of my Aleph J started to behave strange, turned both channels on in the morning for an hour or so of listening after which both were functional, after this they were turned off for 2-3 hours.
oh well now after those 2-3 hours when I start up one of my channels generates noise(0.4V) only if it has the input cable attached(it produces the noise(hum)even if at the other side of the input signal cable isn`t nothing connected).If I let the input with nothing attached the output is quiet
I have no idea from where to start...
Old 1st December 2013, 12:45 PM   #1755
I think it`s time to change interconnect cables
Old 1st December 2013, 03:14 PM   #1756
BobEllis's Avatar
Or at the ground connections of that amp channel - the heat after a few hours could be affecting a shaky solder joint. Could the bad side input jack be contacting the chassis?
Old 1st December 2013, 03:54 PM   #1757
Any suggestions on a source for REAL 2SJ74s? I need two for a repair. The ones I'm using are from AMB and none of the others I've tried come close to their specs.
Old 1st December 2013, 03:55 PM   #1758
6L6 is offline 6L6  United States
6L6's Avatar
Have you asked Ti if he will sell you some for that reason?
Old 1st December 2013, 04:01 PM   #1759
I have not asked - perhaps I should. Thanks
Old 1st December 2013, 09:12 PM   #1760
No go on jfets from AMB. I decided to try a lot of LSJ74s from the DIYAudio store because I have zero confidence in the supposed Toshiba J74 parts from any other vendor than Ti.
Unrelated question on the topic of the Aleph J. My Buffalo/Legato DAC doesn't put out sufficient voltage to make this amp sing and I've read others have used 1:2 input transformers. Any comments or recommendations on a specific Lundahl part number? [Preferably one transformer per balanced channel]
Frank
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright 1999-2017 diyAudio
