Aleph J Schematic - Page 165 - diyAudio
Old 18th March 2013, 01:37 PM   #1641
Runcis is offline Runcis  Latvia
Taking in account the last quote buy Qusp & that IPFP9240 has 125pF larger input capacitance than IRFP240, I must use 2 pairs of output devices for I have only 4Ω booomboxes right now.
Old 24th March 2013, 06:32 PM   #1642
Zen I need a little help from you
I want to change ac signal coupling caps of my dac and line pre, and I was thinking if I can replace input pot of my line pre from 100k with one of 200-250k so in this way I will need a cap of a lower value on the stage before him right?
correct me if I am wrong
what else will change along with pot value?
I use second schematic
Old 24th March 2013, 06:48 PM   #1643
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
using anything more than 50K for volume pot will introduce cable talk
that will be much more important than any cap issue
whatever cap you have as output on preceding stage , bypass it with MKC , or make another config , which will be DC coupled
however - I'm resorting to DC just because I can , not because cap in chain is most critical link ...... looking at that toob stage , I'm finding it more critical than any cap
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th March 2013, 07:13 PM   #1644
cable talk means?
Old 24th March 2013, 07:22 PM   #1645
Zen Mod's Avatar
influence of cable capacitances yukyuk
Old 18th April 2013, 10:19 PM   #1646
Hello, I just completed my second Aleph J, but this time one channel is very quiet. Everything seems to be working fine ( still sounds great just doesn't have the gain. Any ideas on where to start?
Dave
Old 21st April 2013, 04:17 AM   #1647
Could this possibly be related to a bad ztx450 @ q4? or would it most likely be the input jfets?
Old 21st April 2013, 08:55 AM   #1648
Danger Mouse's Avatar
At my amp i can reproduce this by not grounding -input when using unbalanced input. Then the amp should have a gain of 1
look from your -input to the inputpair maybe there is a problem.
Old 21st April 2013, 04:23 PM   #1649
That was the first thing I checked...can't seem to find a problem there. When I unground the -in there is a slightly lower gain, but not by much. I'll have to check it again.
Dave
Old 21st April 2013, 08:22 PM   #1650
Zen I`m planning to change all resistors in the circuit(rn55d) with cmf55-143 which are non magnetic.what do you think, it worth`s the try?
what non magnetic resistors do you reccomend for R16-R23?
aleph 30 schematic kendt Pass Labs 17 24th March 2012 02:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 01:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 09:49 PM
Copyright 1999-2017 diyAudio
