#1471 |
You cut your hair
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#1472 |
ok...so I had to choose between silicone pads for isolator which were factory made and teflon isolators which I have on a role and I had to do another hand work
guess what I choose
#1473 |
What is the thermal performance of the teflon?
#1474 |
sincerely...I don`t know but from what I know it is better than silicone pads, also thinner and you don`t need to use thermal grease, hope I am right
#1475 |
teflon
put goo , just in case
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#1476 |
both sides or one only?
really don`t like very much grease just `cause you get dirty each time you get you hand near...you just can`t miss it Last edited by schultzsch; 18th January 2013 at 07:37 PM. |
#1477 |
well - I put kapton today under few of them , but with goo
getting grease on fingers - just matter of mileage I'm using wooden stick for applying goo (meat spits)
#1478 |
didn`t had on hand kapton, I know it is the best but...maybe in the future if the teflon wouldn`t work fine and the temperature difference between sink and to247 capsule will be too high.what should be the maximum value of this difference?
#1479 |
say that 10C is in highish part of ballpark
there are few threads - search for mica and goop and for Keratherm
#1480 |
Hm... quick search gives: Therm. cond. for kapton = 0.37 W/(m*K), Dupont web page, and for example for Alum. Oxide = 60 W/(m*K)(Wiki), so it is two orders. Why not just buy Al2O3 based pads?
| aleph 30 schematic | kendt | Pass Labs | 17 | 24th March 2012 01:38 AM |
| Aleph 60 schematic? | roger-k | Pass Labs | 2 | 29th January 2006 12:49 AM |
| Aleph 5 schematic Q | Kovax | Pass Labs | 2 | 1st July 2003 08:49 PM |
