Old 9th January 2013, 09:22 PM   #1431
hope there it`s nothing that bad...on the preamp side
thanks for your help
Old 9th January 2013, 09:25 PM   #1432
buzzforb's Avatar
Turn on and see if voltage at output slowly goes away. If so, I think ramp up is issue, as I don't see another way to have same results.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 9th January 2013, 09:29 PM   #1433
yes after the peak it goes away
Old 9th January 2013, 11:09 PM   #1434
buzzforb's Avatar
Lets see if ZM chimes in. It could be overshoot from your PSU as another option.
Old 9th January 2013, 11:24 PM   #1435
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
bloody bleeding resistor on output
is missing , of course
and yeah - short circ between two headphones
next time use 220Vac from wall instead of amp , to prepare speakers for listening session
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 9th January 2013, 11:29 PM   #1436
buzzforb's Avatar
I did assume the bleeder was present, as it is in the schematic.
Old 9th January 2013, 11:44 PM   #1437
Zen Mod's Avatar
maybe yes . maybe not
whatever - powering tube pre in same time or after power amp is ......... just not worshiping as it needs to be ..........
either culprit is in SS HV or elsewhere
who cares ?
either put delayed mute relay on pre output , or use da unshorted circuit between two headphones
Old 9th January 2013, 11:57 PM   #1438
buzzforb's Avatar
And I thought I had it working for a second.
Old 10th January 2013, 02:23 PM   #1439
I have bleeding resistors on output of 100K.
Could there be any problem for the input jfets of the aleph if on the input arrives 20Vdc and the amp is shut down?
in the future I thought to redesign the preamp and I think mute relays will be an option
Old 10th January 2013, 02:40 PM   #1440
Zen Mod's Avatar
that's not DC , but surge AC voltage
it happens in moment of gas tubes firing
see datasheets
so - I repeat - either muting relay on pre out , or power up power amp about 1min later
don't make big issue of it - normal behavior
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright ©1999-2013 diyAudio
