#1381 |
Look on the fourm about ACS explanation. Altering R27 changes the the acs gain/modulation and with it, contribution of upper fet to output. Nelson decided on his values for a reason and I would imagine it is better overall performance. I have read that performance at 1w can be improved slightly, but at the expense of performance at higher power levels.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#1382 |
in the future I wish to listen to the amp without R27(pure class a) in the circuit but the bias on my side is already high(1.6A/fet and 60C on the sink measured last summer) and I don`t want to get everything on fire
![]() How high the bias/fet gets in the original circuit without R27? |
#1383 |
THE bias of the current source is .65V divided by the Rs of the top fet. If you cut modulation component, then you have a SE amp driving a CCS load. With 1.6a, you better have beefy sinks. The original was bout 1.2A(.66/.47)
#1384 |
I don`t understand, 1.2a with or without R27 in the circuit?
#1385 |
ups
i did it againfor pure class a I have to remove R24 I remember now that i read somewhere here that also without R27 the sound gets better confused you a little bit..sorry Last edited by schultzsch; 3rd January 2013 at 07:19 PM. |
#1386 |
Here is basic schematic. If you want to have just SE amp with CS, you dont need R24, r27, r20-23, and c3. These are the componenents that turn it into a modulated current source, where the signal affects the response of the current source and its contribution to the output.
#1387 |
so the trick it`s that I have to remove all those components to achieve pure class a, not only R24...ok now I get it
you cleared a little bit the things for me, thank you! |
#1388 |
Look at Zen V2 article on Firstwatt site. The second part of the article he sets up a SE amp with a CCS load. He follows that article up with ZV4, where he introduces the ACS. THe AJ just adds a LTP too the front end and creates nice feedback point as well as ability to drive with balanced signal.
#1389 |
#1390 |
thanks!
another day of work.. |
| aleph 30 schematic | kendt | Pass Labs | 17 | 24th March 2012 01:38 AM |
| Aleph 60 schematic? | roger-k | Pass Labs | 2 | 29th January 2006 12:49 AM |
| Aleph 5 schematic Q | Kovax | Pass Labs | 2 | 1st July 2003 08:49 PM |
