Old 5th December 2012, 05:26 PM   #1371
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
pics
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 5th December 2012, 06:00 PM   #1372
kroyin is offline kroyin  India
Since there is nothing to debug :-) pic of the crows nest.don't flame me for the long input output wires, I driiled the holes wrong (short circuit in between two God given headphones :-) )
Old 5th December 2012, 06:06 PM   #1373
& the outside,even better :-)
Old 1st January 2013, 09:28 PM   #1374
albertNL's Avatar
I hope someone can explain some things for me.
I have been looking at the manuals (user and service) of the A3, A30 and AJ and have made some notes of the differences. I then tried to relate the differences by comparing the amps schematics, but there are too many variables for a newcomer like me to explain the specifications. I hope you guys can give me a hand.
Rails are about the same:
A3 and A30: 25V
AJ 24V
Gain:
A3 20dB
A30 20dB (balanced) 26dB (single ended; manual explains that A30 has 6dB greater dynamic range than A3)
AJ 19.6dB (does not specify a difference between balanced and single ended)
I understand the higher gain of the A30 is due to the input stage. Is this correct?
Power used:
A3 and A30: Each channel draws about 100W
but:
A3 250W consumption
A30 and AJ 200W consumption
Question:
If A3 and A30 both have each channel drawing 100W, should total consumption not be similar?
Active output stage biased by current source at
A3 slightly greater than 2 amps
A30 slightly less than 2 amps
AJ not given
Max. output:
A3 30W/8R, 60W/4R, 60W/2R
A30 30W/8R, 40W/4R
AJ 25W/8R, 13W/4R (Firstwatt product table)
Question:
What causes the difference between 4 Ohm output of A3 and A30? I assume it is the "slightly greater" and "slightly less" than 2A bias that is the cause. Is this assumption correct?
Question:
How come the AJ has so much lower power into 4 Ohm? I assumed that, since total power consumption is similar, bias must be similar.
Max output
A3 23V 8A
A30 25V 5A
AJ 21V 2.5A
Questions:
What causes the relative large difference between A3 and A30?
Are the numbers for the AJ correct? If so, why so different from A3 and A30?
Thanks,
Albert
Old 1st January 2013, 09:45 PM   #1375
Zen Mod's Avatar
whoa !
will write reply ......... in few days , not after NY eve
'ts time for sandwiches and moves , these days
Old 1st January 2013, 09:46 PM   #1376
albertNL's Avatar
Originally Posted by Zen Mod View Post
whoa !
Thanks! Hope your head does not hurt too much.
Old 1st January 2013, 09:48 PM   #1377
Zen Mod's Avatar
naah
too old for much rnr
Old 3rd January 2013, 04:59 PM   #1378
A journey started a long time ago...
hope to finish it soon
Happy New Year to all!!
Old 3rd January 2013, 05:21 PM   #1379
buzzforb's Avatar
excellent job so far.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 3rd January 2013, 06:05 PM   #1380
thank you!
I would like to use 2 switches in the final product, one to turn on/off aleph ccs and the other to adjust the bias(-r27minum value -no r27 - r27 at actually value)
how can i calculate the minimum value of r27? I have the source resistors of 0.33r
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright ©1999-2013 diyAudio
