Aleph J Schematic - Page 137 - diyAudio
Old 5th December 2012, 01:21 PM   #1361
BobEllis's Avatar
Try repeating the test on your preamp, both connected to your amp and alone. How much can you get out of it to driving the amp? Is the output voltage lower with the amp connected?
I'm guessing that although amp gain is correct, your feedback network resistors may be an order of magnitude lower than expected (1K input instead of 10K), presenting a low impedance load that your preamp cannot handle.
Old 5th December 2012, 01:43 PM   #1362
kroyin is offline kroyin  India
Preamp is B1 ... tested before ...unity gain .. x in x out..
As per the readings in my previous post my AJ is working as expected ..right? ??
Old 5th December 2012, 01:55 PM   #1363
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
source , preamp , speakers , what's gain of F5 ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th December 2012, 02:16 PM   #1364
Question first :-) is 10x voltage gain par for AJ?
Source-linux->wm8741 dac->b1 with 2x50k mono pot (same setup for F5)
Speakers are 90db 2.5 way troels gravesen nomex
AJ (F5 before that) uses the same trafo, same psu & caps.
F5 biased @ 1.3A (single pair) with 20dB gain (200r resistors)
Old 5th December 2012, 02:17 PM   #1365
BobEllis's Avatar
A B1 ought to be able to handle the amp and not load the source significantly. Measure the source's output into your B1. You should be able to find some full scale signals to burn to CD to test with.
You may need a little gain in the system now. One easy way would be to increase the gain of your AJ a bit, but of course that would impact its sound.
Old 5th December 2012, 02:25 PM   #1366
BobEllis's Avatar
And yes, 10x voltage gain is 20 dB, so the amp is working correctly.
Have you tried with the exact same music with the new amp (too bad you can't do a side by side comparison)? Apparent loudness of individual tracks can vary widely. It's a bit surprising to me how soft so many of my older songs sound compared to modern recordings and 30 years of loudness wars. I find myself riding the volume control as I shuffle through my ripped music collection.
Old 5th December 2012, 02:32 PM   #1367
Well song was Floyd Us & Them & yup I have heard it on both setup..
If the AJ is setup ok,I can build Jumas preamp (meant for F5)
Old 5th December 2012, 02:52 PM   #1368
Old 5th December 2012, 04:50 PM   #1369
Zen Mod's Avatar
well - you made your measurements
it seems everything is OK
Gremlins in action , maybe ?
btw. I'm quite often finding that short circ between two headphones is troublesome for me
Old 5th December 2012, 05:21 PM   #1370
:-) grounding gone bad ....there's buzz, hell they even came up with a fancy name ..tinnitus
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright 1999-2017 diyAudio
