Aleph J Schematic - Page 136 - diyAudio
Old 5th December 2012, 07:54 AM   #1351
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
pictures ; exact schematic you used ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th December 2012, 08:28 AM   #1352
kroyin is offline kroyin  India
ZM, PCB is mostly as per post 687 (guess he is Jims Audio :-)).
Circuit is default as per published (only change is BC550 hfe ~500 & BC560 hfe ~300)
-VE, RCA Gnd, SPK Gnd go to one GND hole on PCB while the other GND hole is connected to PSU gnd via a thick wire.
Will take some pics when i get home
Old 5th December 2012, 08:38 AM   #1353
Zen Mod's Avatar
willing to do some simple measurements with DMM ?
absolute precision isn't important , just relative
if you don't have sig gene , download this : https://dl.dropbox.com/u/20665608/SigJenny.zip and use output of PC sound card as gene
set to 400Hz
put DMM in Vac mode at amp input , set PC volume at 100mV , then reconnect DMM to output
write down result
Old 5th December 2012, 08:47 AM   #1354
No problem...i can use ARTA, to generate a test signal @ 500mV and test the AC o/p from the amp's out
Old 5th December 2012, 08:50 AM   #1355
Zen Mod's Avatar
even better
just stay in 300-500Hz region , because there DMM is precise enough
Old 5th December 2012, 08:54 AM   #1356
Originally Posted by Zen Mod View Post
even better
Ok i'll see whether i can figure that out :-). In fact ARTA as part of the sound card calibration gives out a default test signal at a user specified voltage and then asks to measure the A/C output
Old 5th December 2012, 08:55 AM   #1357
Zen Mod's Avatar
use Sig Jenny
it's more versatile
Old 5th December 2012, 08:59 AM   #1358
use Sig Jenny
it's more versatile
Thanks i'll do that and report back
Old 5th December 2012, 09:34 AM   #1359
Zen Mod's Avatar
disclaimer - it won't work on 64b systems
Old 5th December 2012, 01:03 PM   #1360
Zen..ran the test
Input --Sine wave @ 210mV AC both channels
Output- 2.1V AC on both channels.
So 10x voltage gain ~20dB (right)....now what :-)?
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright 1999-2017 diyAudio
