Aleph J Schematic - Page 132 - diyAudio
Old 25th November 2012, 10:26 AM   #1311
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
let it play for a while
what's voltage ditto across zener ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th November 2012, 10:46 AM   #1312
kroyin is offline kroyin  India
Across Zener 9.4x V
Old 25th November 2012, 11:15 AM   #1313
Zen Mod's Avatar
that mosfet connected to R17 is somewhat off (unmatched) , but it can't be main thing for your (un)satisfaction , against F5
check AC gain of Aleph CCS , just in case
whatever , I always preferred Aleph J to F5 , at least with my spks and my ears
Old 25th November 2012, 11:48 AM   #1314
Zen, as I said things which are harsh with F5 are mellower with J.
So J at the very alpha stage suits me better than 5.
But I need to do the 2nd channel and connect them to my 2.5 spks(90db with woofers going down to 7.1 ohm -- same characteristic as the 2 ways that 6 moon reviewed the J with) to come to a conclusion
In itself are my readings any cause for concern
Old 25th November 2012, 12:12 PM   #1315
Zen Mod's Avatar
sorry for miss-read from my side
just woke up , prior to that post
well - if you have no better matched mosfets , just leave them as is and be
that was one of the reasons why I used IRFP150 in my Babelfish J - just one pair/ch. , no matching required , lesser capacitances blahblah
no matching was main reason
Old 25th November 2012, 12:32 PM   #1316
Nah no more matched stuff :-(.Guess the source resistors also there as an insurance against badly matched mosfets.
The other channel will be with BC critters & some changes to the grounding scheme.
Right now RCA gnd is of the amp PCB,while IN- & out gnd is off psu gnd.
Will lift the RCA gnd off the psu gnd & see whether the buzz goes
Old 25th November 2012, 12:53 PM   #1317
Zen Mod's Avatar
make them all off pcb gnd
just one fat wire going from PSU gnd to pcb gnd
Old 25th November 2012, 04:51 PM   #1318
Thanks, I'll do the second channel.
By the way what kind of effect will the mismatch have on sound ..I check the Vgs in circuit
one has ~100mV less than others.Worth the effort changing the pair :-)?
Offset is fine though ~25mV
Old 29th November 2012, 01:09 AM   #1319
6L6 is offline 6L6  United States
6L6's Avatar
Is there anybody out there that knows PCB design and could design an Aleph J board for the Universal Mounting Spec?
Old 29th November 2012, 02:26 AM   #1320
craigtone's Avatar
19 years of PCB design here. I'd love to help and ironically enough I was planning to build an Aleph J this winter ...
I have the Aleph J schematic if someone can educate me on "Universal Mounting Spec", I can start tomorrow.
Craigtone Audio
Paradox DL-103R, P2-24, Pearl 2, Apollo-R, D100 Mk2, Mezmerize, TSE 45, ALK Klipschorns
aleph 30 schematic kendt Pass Labs 17 24th March 2012 01:38 AM
Aleph 60 schematic? roger-k Pass Labs 2 29th January 2006 12:49 AM
Aleph 5 schematic Q Kovax Pass Labs 2 1st July 2003 08:49 PM
Copyright 1999-2017 diyAudio
