#1301 |
#1302 |
LOL!
Regardless, we all know that it's an addiction with no known cure. (I am currently making an order to make a 'universal' external PSU for my Pass/Firstwatt amps. A box with the transformer, bridge, caps, etc... so I only have to pay for/build one powersupply, and just make amp channels on heatsinks or in smaller chassis. Not having to buy a PSU for every amp means that I can try more of them! Hooray!) See, it's not just you.
#1303 | |
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#1304 |
Yes a seperate p/s is an excellent idea.I have a set of PD's Aleph J boards assembled and waiting in the wings but I'm going to have to disassemble my F5 to put it together.Was thinking of just swapping out the pcb's and heatsinks but the last quote for heatsinks unanodised was 300GBP's talk about rip off Britain!
#1305 |
Ideally one case only having large heatsinks, a multitapped transformer and high enough voltage rated caps of consequent capacitance might serve for most of amp boards to try including classA, AB, Or even chip amps.
You'll end with many holes into the heatsinks though is that a problem? If you can't stop building amps it will go cheaper. |
#1306 |
Yes, exactly. Nothing complicated... merely oversized (600VA transformer) with 100,000uf per rail, convenient, (Speakon connections for the power umbilical) and in a nice box to look good.
#1307 |
Hi guys,
Today I finally connected my new Aleph J to my main system. It would take too much time to set up in my study, so I decided to take the plunge in the main system. It replaces my Pass Labs built Aleph 3 and runs mid/hi on my 4 Ohm Magnepan MG3a's. Not an ideal marriage, but .... SHE SINGS! First impressions (single ended input):
I will not try to explain the differences at this stage, but just enjoy the music! After a week or so, when it is burnt in properly, I hope to be able to do some comparing and also try out the balanced inputs. A friend of mine built a pair of Aleph 2 monoblocks for me about 6 years ago. I intended to use them in my main system because the Aleph 3 is a bit small for the power hungry Magnepans. While the 2's sound very nice, they could not match the Aleph 3 in sound quality and ended up in my study. Having just switched on the J it is interesting that I do not (yet) miss the 3. Having built my first power amp I now plan to take the Aleph 2's apart ![]() I have already seen that some parts could do with upgrading (Silmic caps, better internal wiring, small film caps in PSU, etc). I will try to get the 2's to sound closer to the 3. Depending on how the J settles down, I might end up converting the 2's to a jfet front-end, but will need serious help from you guys if I do! Thanks everyone, I am a very happy builder! ![]() Albert |
#1308 |
naah
it's easy - few Jfets and few bjts for cascodes
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#1309 |
I know this feeling, to be a happy builder...... Good hearing!
and the First W tt is......a really First Class P SS Idea !
#1310 |
I succeeded in stripping 1 F5 Chanel & replacing with Aleph J
Matched mosfet, jfet. ZTX critter.Here are my voltage readings R7-4.92V R8-8.94V (case of Zener not dropping 9.1V??) R16-.521V R17-.610V (??) R18-.563V R19-.557V No voltage across R20/21/22/23??? Offset after 1 hour 27mV.Plays music, things which sound harsh with F5 are mellower. Any concerns with the above??? |
| aleph 30 schematic | kendt | Pass Labs | 17 | 24th March 2012 01:38 AM |
| Aleph 60 schematic? | roger-k | Pass Labs | 2 | 29th January 2006 12:49 AM |
| Aleph 5 schematic Q | Kovax | Pass Labs | 2 | 1st July 2003 08:49 PM |
