#21 | |
Oh yes, I forgot to mention the PSU, but it's important that it's a CLC filter, as the PSU noise rejection of this topology is not very high. If only using a C filter, you can hear the 100Hz when using sensitive speakers. I found that 5mH and 2*68.000uF keeps the noise down. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#22 | |
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#23 | |
#24 | |
Formerly "jh6you". R.I.P.
I'm lucky: I'm an engineer . . .
#25 | |
The one and only
Disabling the AC current gain in the current source does result in a different spectrum because the circuit cancels some second harmonic. At the same time though, it dramatically reduces the total distortion by effectively doubling the load impedance. So you have a choice - Lots of second harmonic with lower power, or much lower distortion. Me, I was pleased to see THD figures as low as .003% at 1W, 1KHZ. You would not see anything like that with the constant current source.
#26 | |
I wonder if this is one of those cases where it's the distortion people like? Magura ![]() EDIT: Untill I have found the graphs that showed the non liniarity of the active current source....let's just say that it's my memory playing tricks on me
#27 |
The one and only
I have no argument with those that say they like the sound of
a CCS over an Aleph, or those who like the sound of a resistor or a CCS, but curves is curves...
#28 |
I guess that the speaker load should be taken into consideration too. A 3-way bass reflex speaker would probably sound better with the active CCS while Lowther or Fostex drivers might sound better without it.
#29 | |
Lightning In A Bottle
Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html |
#30 | ||
The test was performed with a FE166E based Abbey clone, so we agree this far. What I don't understand is why, now that Nelson tells us that the Aleph current source is 100% liniar all the way? He is right that the regular CCS does result in higher distortion. Magura
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 5 | 13th October 2012 05:18 AM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| "Void free" or "no core gaps" plywood | rick57 | Multi-Way | 6 | 14th March 2007 01:09 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
