RIP
Well, I made a couple boards and installed them in a Rotel 971, fired it up and checked everything out. Input offset zeroed out and all voltages where they are supposed to be. It sounds great, very transparent and deep, but the output level isn't anywhere near where I thought it would be.
This is my first attempt at any circuitry around a dac chip and I either missed something basic or I need another gain stage. On a -10db test disc I have around 25mv output.I have the Iout and BP0 pins going straight to the board inputs and picked up the ground near the PCM63s. Somebody straighten me out, you can even yell if you want. Bill |
#2 |
A few questions:
What DAC Chip are you using? What is the DAC's current output? Let us know the MOSFET's voltage supply. -David |
#3 |
RIP
I am using all the rotel circuitry up to and including the PCM63s. I have a 25VA transformer and regulated PS set at +/-28v for the I/V board. I have lifted the jumpers that connected the Iout and BP0 pins on the PCM63s to the stock output stage, tied them together and fed that point to the input on the new board.
The PCM63s are supposed to put out +/-2ma which is the design parameter of Mr. Pass' circuit. I believe I have it hooked up exactly as intended but checking the signal level at the board input with a test disc playing the -10db track I am reading about 4mv. Is there a mute function that I have inadvertantly enabled when I Isolated the outputs or does that sound like a normal signal. I also experimented with a 100ohm resister load and got the same signal level, about 4mv. I realise they are current outputs but shouldn't the load voltage be higher? The thing is when I put it back to stock configuration it plays fine, and I've done that 3 times. As I said, the new board sounds really great but the level is so low it is not practical to operate with the rest of my system,so in other words the operation was a sucess, but the patient died. Anybody got any theories or any more questions? Bill |
#4 |
Since the new I/V is working, just not loud enough, I'd look at the resistors you have for biasing the buffer FET's.
When I sim'ed the D1 I/V, the diffeerence between 28 and 30 vdc supply is about 1 volt on the output. Try dropping the values of R28 and R34 from 1k5 to 1k. This should raise the output voltage about 3 volts with a +-2ma source and a 28vdc supply. -David |
#5 |
RIP
Thanks David, I'll try it tonite and report the results. Much appreciated. Bill
#6 |
Are you using the original DAC on the Rotel? What is the output current and the center current?
CT |
#7 |
RIP
I haven't had much time to mess with it the last couple of days but the buffer section is just a source follower so there isn't any gain in that section, unless I'm mistaken.
The Dacs are PCM63s- output is 0 to -4 plus +2, equals +- 2ma. Might not be turning on because of too low a supply, going to try larger trans, wont fit in case but if its successful I'll buy a new one that will. Any other questions or input? Thanks all, Bill |
| My ESL attempt | SM7UYJ | Planars & Exotics | 144 | 4th March 2010 01:22 PM |
| First attempt | j beede | Planars & Exotics | 21 | 27th December 2008 04:31 AM |
| First DIY amp attempt! | RTF671 | Instruments and Amps | 8 | 8th June 2008 02:22 AM |
| first pcb attempt | m0nty | Solid State | 3 | 25th September 2005 04:07 AM |
| First attempt...Elf 1.5 | sheik | Multi-Way | 0 | 1st August 2003 02:03 PM |
| Page generated in 0.09196 seconds (76.47% PHP - 23.53% MySQL) with 10 queries |
