diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Mounting power transistors (http://www.diyaudio.com/forums/pass-labs/110840-mounting-power-transistors.html)
loovet 27th October 2007 09:46 PM
I’m now at the stage where I will mount my transistors to the heat sink and have some questions regarding this. I will be using metric M3 screws to mount the transistor and the “base” of my heat sinks are 8 mm thick, so the depth of the hole it self will probably be some 7 mm.
When mounting a power transistor to the heat sink, how much power should one use when tightening a screw?
Are you all using a bottom tap when making the threads? Ore are you using a normal throughout tap?
Any tips to make it as good as possible?
Thanks in advance
/loovet
carpenter 27th October 2007 11:19 PM
Lacking a torque wrench, I just make mine snug--don't reaf on the screwdriver or wrench (which ever you use). You should see some heatsink compound squeeze out from the mica.
A small-handle screwdriver is safer in that it's more difficult to over tighten the screw.
Haven't lost a transistor yet due to thermal management.
jupiterjune 28th October 2007 01:17 AM
loovet-
You can get away with either a bottom tap or a through hole tap with 7mm deep holes. 8mm is a righteously thick backplate! 5 mm of thread should be plenty for those screws.
I'm not sure if an M3 is closer to a #6 or a #4. But, a number 4 tap is wee little thing -- very easy to break.
Tip of the day -- I like to use a hand tightening drill chuck (without the drill attached) to tap. If you don't tighten it up too much, the chuck will slip when you hit a rock, rather that breaking the tap. Also, it makes it easier to turn the tap rather than pushing it -- which tends to break small taps.
JJ
Andersonix 29th October 2007 01:02 AM
It sounds like you don't want a threaded through-hole, so the type of tap depends also on the length of screws to intend to use. I always try to use a bottoming tap for blind holes, but I'm anal like that. (Although I start off with a tapered tap.)
Is there any way for you to make a clamp (or use a big washer) to distribute the pressure on the transistor? If you're dissipating a lot of heat, you might need the extra clamping pressure and need to use a larger screw. Just remember, aluminium is soft and strips easily, so use the exact tap drill (and a pilot drill first) and a tapping guide block to keep the tap straight.
carpenter 29th October 2007 03:03 AM
I enjoyed reading your posts, jupiterjune and Tosh! Words of experience, thanks for sharing.
flg 29th October 2007 09:45 PM
1 More little refrence on the topic...
http://www.onsemi.com/pub/Collateral/AN1040-D.PDF
And there is a few more there somewhere :D
Malotron 29th October 2007 09:53 PM
http://www.irf.com/technical-info/appnotes/an-997.pdf
Originally posted by Nelson Pass
I recommend a nice wide washer on top.
The TO247 case has good support at the hole, and you
just want to avoid cranking down too hard. We use
torque wrenches set at 8 inch-pounds.
For tapping blind in aluminum I would also start with a tapered plug tap and finish up with an bottoming tap to increase usable thread depth and durability as Tosh suggests. A wax lube on the tap helps to draw the cuttings out with the tap and cleans up nicely. IMHO, cutting M3x.05* or M3.5 threads requires a soft touch as the tap will only cut down about 3mm per pass before it clogs up; if you power through this initial resistance there is a fair to good chance the tap will snap off flush in the hole.You will never forget the first time this happens to you (e.g: Cadillac 429ci cylinder head.) :(
*Fine threaded hex bolts + large washers are swell.
-Mal
I used
IRWIN #80213 6 - 32 NC Tap + 7/64" Drill Bit
Lenox H5405 Lube Tube (bandsaw cutting wax and for general machining)
Aavid 4180G ALUMINUM OXIDE PAD TO-218/TO-247/TO-3P (Mouser)
#6 –32 x .625” hex bolts
Homedepot Washers, 1” dia. .125” hole .06” thickness
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
