This is probabily a doomed question but....
the majority of the signal generators out are single ended...which means that they only have one output. speaking of balance circuitry......if you have a signal generator with the above characteristics......it is true that it's possible to shoten the in(-) and evaluate the topology just as a single ended one..... But.... what if i would like to have an input differential signal test and test the entire topolgy? Is it convenient to transform somehow the signal into a differential version? How do you guys generally do to test , let's say, a differential preamplifier or power amp? Thanks in advance for the attention.
Stefano |
#2 |
Simplest solution is to get yourself a DRV134 chip and 4 9V-batteries. Within half an hour of soldering, you have a balanced driver for single ended signals.
Not for listening music, but good enough for test signals. Patrick |
#3 |
Oh really?
Do you have, by chance a simple schematic ...an application... for such as part to make it run as a differential signal generator (sine, sqaure triangolar wave)? I appreciate very much your suggestion.
Stefano |
#4 |
Just Google and download the datasheet. There is a standard circuit.
I presume you have a normal, ground referenced signal generator in the first place. Patrick |
#5 |
ah ok...now it's clear....
so normal single end signal generator and then using this component to have a differential output signal. Thanks.... i'll download the datasheet.
Stefano |
#6 |
ahhh.......do you know where i can find this part????....
do you have, by chance....any suggestion?
Stefano |
#7 |
Schuro in Kassel(D) undoubtedly offers it, check their online pages.
or RS-Components Italy, for a few euros more. (instead of the TI DRV134 you could look for AD SSM2142)
Looks like Sponge Bob has killed another thread. |
#8 |
it's all in germaaaannnn.......or at least it's me that i'm not able to find the english version.....i don't know......how can the rest of the people on the world or even in Europe read it?.....
gggrrr......
Stefano |
#10 |
thanks a lot....
do you think they accept an order for just one part? anyways ..... thanks for the information. ...as a note....hihi....i was taught in high school...and even before....to speak Italian......
Stefano |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 07:18 AM |
| topology for preamp, single ended or complimentary | maxpou | Solid State | 7 | 10th January 2008 11:41 AM |
| Converting from single ended parafeed to differential | dsavitsk | Tubes / Valves | 9 | 12th July 2007 07:46 PM |
| Volume control + Single Ended -> Differential Amp | koolscooby | Solid State | 2 | 6th April 2004 12:50 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.10561 seconds (73.33% PHP - 26.67% MySQL) with 10 queries |
