Old 10th February 2003, 08:01 PM   #1
Default Aleph60 Dumb Question
Hi All:
Don't completely flame me but is the Aleph60 a monoblock? In the service manual it mentions that it is a 60w/channel amp (implying two channels). In addition the manual states that the schematic is for one channel and the power supply for both channels. However, my calculations of idle current would correspond to the approximate 200 watts given in the specification for the overall unit (2.5 amps x 70 volts = 175 watts). So which is it: stereo or mono?
Thanks,
PaulyG
Old 10th February 2003, 08:14 PM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Default Re: Aleph60 Dumb Question
Originally posted by PaulyG
Hi All:
Thanks,
PaulyG
Maybe it is BOTH mono and stereo
Anyway they will soon tell you the answer..
/halo
Old 10th February 2003, 08:32 PM   #3
UrSv is offline UrSv  Sweden
UrSv's Avatar
You're sure you're not mixing the A30 into the picture? The A60 is a mono block and the power suppply is for one channel. The A30 is a stereo amplifier and the power supply in the schematic in the service manual for the A30 states that it is for both channels. Not so in the A60 service manual.
At least this is my understanding.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 10th February 2003, 08:47 PM   #4
My guess is that you are correct that the 60 is a monoblock. Here is the text that was confusing me:
Pass Aleph 60 Service Information.
The Pass Aleph 60 has only two gain stages which are biased by current sources. Because of the inherent simplicity of the circuit, it is easy to understand and repair. There are no adjustments.
Figure 1 shows the simplified schematic of the amplifier. Two p channel Mosfets form an input differential pair biased by a current source operating at about 20 ma. The drain of the input Mosfet is attached to the gate of an n channel power Mosfet which forms the active output stage. It is biased by a current source at slightly less than 2.5 amps.
The voltage rails of the supply are at 35 volts, and the amplifier draws approximately 200 watts.
Figure 2 shows the actual schematic for the power supply and one channel.
Maybe I just read too much into that last sentence. Sounds like I need to have enough heat sink for 200 watts/channel, not just 200 watts total.
Thanks for your help,
PaulyG
Old 10th February 2003, 09:28 PM   #5
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
i may be wrong, but i thought the aleph 60 was the
Volksamp version of the Aleph 5. It's a stereo amp.
The aleph 30 was the Volksamp update of the Aleph 3
the aleph 60 was the Volksamp update of the Aleph 5
but... i might be wrong
moe29
Let's go down the waterfall
Think about the good times and
Never look back
Never look back
Old 10th February 2003, 09:41 PM   #6
Sounds like we need "the one and only" or one of his gang to clear this one up
Old 10th February 2003, 09:45 PM   #7
The Aleph 60 is a monoblock.
Based on the Aleph 2, but at 60W output instead of 100W to use the smaller (more conventional) heat sinks.
There are other improvements to the circuit as mentioned in the manuals, and also in this forum.
Old 12th February 2003, 08:49 PM   #8
PaulyG:
I had the exact same questions after reading the service manual for the 60. Look like the 60 service manual is an edited copy of the 30 manual with a few edits missed.
Mike
"Never confuse motion with action." B. Franklin
Old 12th February 2003, 08:58 PM   #9
Thanks to everyone for their input on this question.
Mike: did you build the Aleph60? It seems to be the right size from a heatsink and transformer standpoint (at least for me )
Paul
Old 12th February 2003, 09:01 PM   #10
The one and only
Nelson Pass's Avatar
Well, that's how I write manuals.
Dumb question, but... johnm Tubes / Valves 3 13th June 2008 10:14 PM
maybe this is too dumb a question... dannyspencer Solid State 6 18th April 2004 04:57 PM
Thi is probably a dumb question.... Konnan101 Multi-Way 4 11th January 2004 01:40 PM
Aleph60 question regarding resistors and schematic.... mats73 Pass Labs 2 5th May 2003 10:04 AM
Dumb Zen V4 Question Panelhead Pass Labs 4 26th April 2003 04:15 PM
Page generated in 0.11299 seconds (87.15% PHP - 12.85% MySQL) with 10 queries
