Pass X150 power down Thump solution = Jensen Isomax (RCA to XLR converter)??
Old 6th October 2007, 07:45 AM   #1
kmtkwong is offline kmtkwong  United States
Send a message via MSN to kmtkwong
Default Pass X150 power down Thump solution = Jensen Isomax (RCA to XLR converter)??
Hello all,
Further to the previous thread about my Pass Labs X150's power down thump, I am thinking to use a Jensen Isomax to convert the RCA to balanced XLR. It is an expensive transformer indeed about $200. I don't know if it is a worthwhile solution for the problem. ALso, is it going to degrade the audio signal, my biggest concern?
Btw, my X150 has no more power down thump if I connect my cd player directly to the amp. I figure it is the DC from my denon causing the problem. I think my X150 is the early production which doesn't have capacitors on the input to prevent DC offset from upstream.
Thanks all
Kelvin
Old 6th October 2007, 08:11 AM   #2
mpmarino is offline mpmarino  United States
mpmarino's Avatar
Why not just put a couple caps at the input and see if it solves your problem? You probably won't even hear it if you use decent ones.
edit: You might still have a small pop but it should be harmless, assuming it's DC that is the issue......
Crazy Yankee.
Old 10th October 2007, 02:21 PM   #3
dejanm is offline dejanm  Austria
Transformer is better solution than cap for coupling (especially if it is comming from Jensen), but it is also more expensive.
Old 10th October 2007, 11:45 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Jensen makes a very fine transformer. Using it provides a
DC connection to ground that you probably were missing.
Pass X150 power down Thump solution = Jensen Isomax (RCA to XLR converter)??Hide this!Advertise here!
pass x150.5 barti Pass Labs 2 18th October 2008 05:03 PM
Gainclone HUM, THUMP problems - The solution gainphile Chip Amps 98 26th August 2008 04:14 AM
X150 produces a "Pop" during power down kmtkwong Pass Labs 5 18th April 2008 05:04 AM
Power off thump (Korsun) 3Dgeek Solid State 0 13th November 2005 10:25 PM
speaker "pop" when x150 power-on dream Pass Labs 13 23rd July 2003 09:15 PM
