Old 5th October 2007, 04:19 PM   #1
traw is offline traw  United States
Default negative output zens to subamp
If connecting a speaker with subamp for bass with high level inputs and using a zen9, would one connect the amp output - to the highlevel in red, amp output + (ground really) to the black of the highlevel input then do 180 phase ship on the bass amp?
Old 5th October 2007, 06:31 PM   #2
The one and only
Nelson Pass's Avatar
The subs usually have a "hot" and a "cold" and the cold is almost
always ground, so you need to connect it to ground even if it
is the "+" terminal at the output of the Zen. Most subs allow
switching of phase, so this isn't a problem, otherwise you can
flip the phase to the main speaker in the wiring.
Current Mirror with negative output impedance rtarbell Solid State 3 27th June 2006 08:19 AM
Full negative rail voltag on my output?? aletheian Chip Amps 1 26th October 2005 04:38 AM
I want to make an amp with a Negative Output Resistance, but HOW?? CeramicMan Solid State 26 3rd June 2004 02:45 PM
Gainclone with negative output impedance Circlotron Chip Amps 16 10th September 2003 10:54 PM
Page generated in 0.06719 seconds (67.61% PHP - 32.39% MySQL) with 10 queries
