Old 9th February 2003, 09:26 PM   #11
Stabist is offline Stabist  Slovenia
Stabist's Avatar
The hum is mechanical - if I put my ear on the top of chassis - you can hear it quite easely ...
The same hum can be also heard on speakers - just that it is even more loud.
BUT - if one interconect is pulled out - almost nothing - speakers are almost silent ...
So - I guess there is a ground problem - there are few things I'll have to inspect - the first one is - there is no 22kR resistor yet .. Then - mr. Nelson allready sugested to ground RCA inputs ..
But - as said - there hasn't been enough time to play with ... And also momentarily the osciloscope is dead So ...
The thing is - the chassis is very compact - and it gets quite crowdy inside - so - Kirc and I must have enough time to try some solutions - it shall be a couple hours job ...
Old 9th February 2003, 09:40 PM   #12
Banned
OK. In my opinion the only consequent thing you can do against the mechanuical noise i described above.
At the speaker, without a long antenna cable at the input, with normal speakers, you should hear nothing. Zen V2 i hear some hum. Zen V4 - nothing.
Old 9th February 2003, 10:31 PM   #13
The one and only
Nelson Pass's Avatar
Toroids are very susceptible to crap on the AC line,
particularly DC imposed by lamp dimmer circuits and
such.
Try putting a couple of 10,000 uF caps back to back
(series) on the AC line to the primary to block DC and
see if that doesn't help.
Old 9th February 2003, 10:46 PM   #14
Stabist's Avatar
mr. Nelson I agree - if there is DC component - trannie can get "overmagnetized" - don't know the expression - I mean - B(H) charachteristic and stuff conected with all that ...
Series of 10.000uf caps between AC power cord and trannie if I understood you right?? Hmm - what about voltage of such capacitors?? 230V is quite high - I'm not sure if there are some 230V/10.000uF caps ... - I mean - am I missing something here or ... ?!?
Old 9th February 2003, 11:03 PM   #15
Banned
10000uF / 63V 4 times in series => 2500uF / 250V ??
Old 9th February 2003, 11:15 PM   #16
Stabist's Avatar
Hmm - it can be clearly seen that it has been a long long day - and that I should allready be in bed for at least 2 hours ...
I've mixed up serial and paralel .... ... Silly me ...
Oh ... I feel so
I feel soooooooo stupid ...
Old 10th February 2003, 08:55 AM   #17
miguel2 is offline miguel2  Portugal
I tried this weekend a DC trap with a 3300uF/25V cap and 4 diodes as in the figure. I noted that when I turned it up it was silent but then the transformer started to hum again.
I am thinking in putting it in a vacuum oven to get the air trapped inside and then bake it. Does anyone knows the baking temperature for these guys?
Old 10th February 2003, 09:09 AM   #18
I really dont under stand why you have theese kind of problems, its just a question about a big enough trafo and enough capitance, then you will not have theese noise/hum problems
Please correct me if im wrong!!
Old 10th February 2003, 09:20 AM   #19
I am using a 800VA toroidal.
Caps are 20000uF per channel.
I do believe my transformer is a bit old but toroids are said to be lifetime guaranteed .
Old 10th February 2003, 09:50 AM   #20
Are you sure it is your transformer that makes the hum?If it is I would not believe in that gaurantee,it could also be the grounding problem or even worse dried out caps!
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
