Hi Everybody,
Has any one have tried to made super symetry in AB class use bipolar transistor ? |
#2 |
I seem to recall hearing of people building an Aleph-X with bipolars. I can't remember the particulars at the moment.
There's no reason not to use bipolar transistors. The topology is not explicitly based on MOSFETs (or JFETs, for that matter). Go for it. Grey |
#3 |
The one and only
The first one I built was with a bipolar OS.
#4 |
dont mind to share the reason to use MOSFET in comercial amp ?
The reason I want to use the bipolar especially in pushpull are its easier to find but if any body can help to me to use FET but not in single ended especially in quasy complementary I very apreciate |
#5 |
The one and only
Mosfets simply work well for me, I get the sound I want and they
don't break. I can get similar, although not identical, performance from bipolar devices (or tubes for that matter). Complementary power JFETs would be my preference, but I don't want to invest the millions it would take to develop them.
#6 |
Here's one nice bipolar X design. It's biased in Class-A, but I think it can be biased to Class-AB without problems.
ExtremA and thread on the forums ExtremA on diyaudio
Regards Robo |
#7 |
want to invest the millions it would take to develop them. Mr.pass Dont mind to explain ? I am confuse |
#8 | |
The one and only
JFETs for use in the output stages of their amplifiers. This met with only limited success, and they eventually discontinued their manufacture of the amplifiers and also the power JFETs. Since then, power JFETs have been unavailable, until a couple of years ago when Lovoltech (now known as Qspeed) came out with some N channel high current JFETs that could be used in the output stage of a power amplifier. As far as I know, I'm the only designer to put them to work, in the First Watt F3 and the DIY version "ZV8" and "ZV9" projects. I continue to sell F3's, and I have some more product under development. However, these are N channel parts only, and in addition, it would be nice to get the Vds rating up above 25 volts and the chip into a TO-3P package. I have been informed by the people at Qspeed that all this would take vast sums of money, and they don't have an interest in the audio market. Presumably they don't see enough potential volume. I can understand that - I myself am not willing to put a vast sum of money into it. Nevertheless, the existing parts manage to achieve distortion levels as low as .003% with only a single gain stage - they can be very linear parts.
#9 | |
Lightning In A Bottle
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
#10 |
Mr Pass,
I understand your reason better. thanx actually I want the class AB amp with super symetry because I need a power amp for my tiny rental company. I need at least 600 watt RMS to drive a pair my mid driver. single ended is out of question so class AB is a better choice for me. actually I can do it (calss AB) use MOSFET I have 200Pcs 2SK2698 but do not have a complementary made me nervous to try a quasy complementer. so next logical choice is complementary bipolar because its easier to find locally. any help or suggest are welcome |
| Simple and tested bipolar transistor amp | sekanix | Solid State | 41 | 19th June 2008 11:42 AM |
| bipolar transistor fundamentals... help help! | oldeurope | Solid State | 5 | 7th June 2008 07:52 AM |
| Ono Bipolar Transistor Replacement | rsbay | Pass Labs | 1 | 11th May 2008 04:59 PM |
| Bipolar transistor Hfe values | k1jroth | Parts | 19 | 20th December 2004 04:17 PM |
| Need simple bipolar transistor pre amp | willy | Instruments and Amps | 3 | 19th December 2003 09:25 PM |
| Page generated in 0.11646 seconds (80.40% PHP - 19.60% MySQL) with 10 queries |
