#11 | |
Account Disabled
JH |
#12 |
hi,
my problem is othe way round. my gain is too less. i use a elna 5k attenuator in output of bosoz and my gain is too less. what kind of options do i have . i dont want to lower R15 because of higher distortions. whats with using a 100k pot instaed of a 5 k pot? or soldering the pot to the input of bosoz? greets, Ralf |
#13 |
Ignatz,
one of the good thing I mentioned was the fixed paralelled resistor, no matter if dual to GND or single between phases. Only drawback of this is the fact you can not get "full" volume, but if you have enough system gain itīs no problem. Of course one can question if this would be audible, but it sure is a more simple "circuit" in that a part of the signal (or all of it) always go thru a soldered path instead via the rotary switch (or what have you). The fixed resistor is chosen via listening test for the max volume you need in the system. I for instance could never use the full balanced source signal level from my SACD, then the volume would be far to loud for my room/setup. So you see, you can use three (your way) or four (my way) quality resistors which make out most of the attenuator, and then use lower quality for the switch or pot. If one uses "your way" with one paralell resistor, the common mode thing could be better while "my way" still has some of that in the single variable resistor in the switch, but the benifit of paralell resistor to GND is that the input capacitance could be less of a problem since it sees a lower resistance to GND. Otherwise (depending on the topology I guess) if the input has no resistor to GND between input terminals and first stage, then the only path to GND is via the series resistor in the attenuator... do you understand now? The capacitance in cables and inputstages (of particurlary FETīs) is troublesome and a source to distortion especially when passive volumecontrols are used. By using a high current outputstage in the source you can use a low value for the attenuator and in that way the circuit damping factor is much better, especially if a low value resistor to GND is used after the series element. Some people have problems with passive solutions, I say, made right itīs the very best. My recipie for a passive set up; A source with 50-100 ohm output capable of driving 100 ohm or at least 600 ohm without problem. Use a low series resistor (500 ohm - 2k) and use fixed resistors to GND after the series element to give the att, a LOW output impedance and to set the max volume of the system. Then use resistors or potīs of choice between the phases for volume control. /Peter |
#14 |
Gotcha! I think I found what has been missing...also the fact that the circuit gain will be reduced as output potentiometer value is lower.
I'll try to find a lower 4-deck potentiometer. To Ralf, I would suggest that we follow the recommendation in the document "<=25K"... Thanks, RR. |
#15 | |
Account Disabled
JH |
#16 |
I know...I know...It was my mistake...
By the way, I tried last night fixed parallel resistors seemed to help...If I could not find a lower value 4-deck POT I may end up with the circuit revision (with proper fixed paralleled R(s)) or 2 x 2-deck stepped attenuators that may be easier to find locally (of course lower value than the current 100K). Thanks, |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| BOSOZ Balanced volume control revisited | kennethrl | Pass Labs | 7 | 21st December 2005 12:29 PM |
| BOSOZ volume control | ToB | Pass Labs | 7 | 23rd August 2002 06:39 PM |
| BOSOZ Selector/volume control wiring? | SteveA | Pass Labs | 4 | 2nd March 2002 03:07 PM |
| BOSOZ Volume Control | rothko | Pass Labs | 5 | 23rd January 2002 03:38 AM |
| Page generated in 0.10168 seconds (77.49% PHP - 22.51% MySQL) with 10 queries |
