This is the finall version of the amplifier I`ve been working on lately. It is a class A amplifier single ended with impemented "aleph ccs".
30W on 4Ohm load Open loop distortion @ 1W/4Ohm = 0.03 Open loop bandwidth 48KHz (-3dB) CL distortion @ 95% power = 0.08% CL bandwidth 480KHz |
#2 |
ps regulator
#3 |
pcb
#4 |
What I`d like to ask is it comensated right and is there any specific type of compensation i should try?
BTW the sound is VERY good and precise nothing like the classic SE amplifiers.. Thanks in advance, Borko. |
#5 |
The one and only
Very nice looking circuit. I would expect that simply
trimming C9 and the Gate/Base stopper values plus potentially capacitance around Q3 (CE or CB) would cover the whole subject of compensation. Easiest to adjust against a square wave into the loads of interest.
#6 |
Thanks mr.Pass I`ll try it.
BTW you , mr.John Curl any many others are proposing low feedback design... I tried to remove (C10/C11) in order to decrese OLG and descovered that amplifier sounded worse. Hi OLG mode sounded more opened with more details! What`s the catch?? |
#7 |
I admit that "What`s the catch??" is a bit silly formulated question, but the listening tests confirmed that the Hi-OLG mode sounded better. I`m bit confused now..
#8 | |
The one and only
#9 |
No problem...
#10 |
Some data:
Q1 current 11.6mA Q2 current 13mA Total bias of output stage = 2A (1A per device) 1. I also tried 2SJ103BL low gm jfet for Q1 ( the only I could find here) and the sound was lot worse, kind a "muddy". 2. I descovered that lowering R6/R7 for higher Q1 gm sound better. |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| KA30se "KRYPTON" SE class A amplifier | bogdan_borko | Solid State | 10 | 30th September 2007 07:57 PM |
| Schematic for Zetex "ZXCD500MOEVAL" - Class D Eval Board ? | CAindoAUDIO | Class D | 1 | 16th November 2006 03:44 PM |
| Page generated in 0.11238 seconds (80.77% PHP - 19.23% MySQL) with 11 queries |
