#1 | |
I thought this better get a life of it's own This looks a lot like what I've been playing around with lately, though I've found it to be ok with massive heatsinking and just one cascode, as opposed to the two you have i parallel. I used a 4.700uF E-cap and a 50uF film cap at the output. A 80mH inductor, and 40V rails. I got a flat response curve down to 20Hz, below 20Hz it starts rolling off, but nothing worth mentioning. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#2 |
edit: just forget...... I found where it coming from ......
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 | |
Sure, thanks. |
#4 |
Who knows what this thread is about... It's a split from another one?
Can a moderator do something about this? |
#5 |
It most likely is an inductor related issue, cause I have seen nothing of it. I use an air core inductor with a DCR of (as I recall) 2.4R.
With a 120mH inductor, you should not experience this sort of problem. Magura
#6 | |
Jfet Cascoded BOZ There is no connection between the two threads. This thread is about an inductor loaded ZV9 style amp. Magura
#7 | |
apassgear, pardon us I suppose a Mod could if they wanted to??? |
#8 |
Great... thank guys
#10 | |
Did you see this post ? Magura
| Copper coil inductor vs. round core inductor | tomchaoda | Pass Labs | 7 | 21st September 2011 04:42 AM |
| Anode Loading Vs. Cathode Loading ? | valveitude | Tubes / Valves | 19 | 22nd July 2005 10:00 PM |
| Page generated in 0.11250 seconds (77.86% PHP - 22.14% MySQL) with 11 queries |
