Old 18th September 2007, 03:39 PM   #11
I would not say I am an expert with an oscilloscope, but I can see ac on the lines after the rectifiers and none at the outputs of the PSU.
Whare should I look next please? Any advice gratefully received!
Old 18th September 2007, 04:17 PM   #12
mpmarino's Avatar
1. Do you have hum when only one channel is connected to the pre psu?
2. Have you tried re-locating the transformers far away from the rest of the pre?
You could try lifting your earth varistor and let the pre psu float - thereby eliminating the possibility of a loop thru earth.
Are you sure it's an ac HUMMM? Could it be noisy protection zeners, or maybe protection zeners (if you have them) are the wrong way around?
Zenny's right, a pic is worth a book.......
Crazy Yankee.
Old 18th September 2007, 04:28 PM   #13
I never said it was an ac humm-just trying to eliminate the obvious!!
Can anyone help narrow down the cause by the fact it is the same in both channels, does not vary with volume and is there with all inputs grounded etc.
BOSOZ Problem vdi_nenna Pass Labs 52 10th March 2008 06:50 PM
Bosoz psu problem vit Pass Labs 10 21st August 2005 10:10 PM
more bosoz problem. when will it end! cowanrg Pass Labs 16 20th July 2005 05:51 AM
BOSOZ PSU problem tcl2 Pass Labs 7 5th July 2004 03:08 PM
Bosoz PSU problem CH2 Pass Labs 3 28th June 2003 04:08 PM
Page generated in 0.07233 seconds (70.13% PHP - 29.87% MySQL) with 10 queries
