Some Q about BSOZ Powersupply
Old 24th December 2001, 01:16 AM   #11
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Default Power trans blues
Thanks for your response.
You are right- this is a SOZ question
Maybe I'll be demoted to an even lower title, my excuse is that it was my first post!
From what I read on the Pass site, the 25 watt monoblock
dissapates more like 500 watts. The 1kva trans is to avoid ripple.
Maybe I misread it , but I've misread it about 50 times if so.....
Those transformers are looking less desireable all the time.
I should have ordered Plitrons in the right size for twice the price.
I assumed that the 4 taps each had a plus and minus, which I thought could be configured into a plus minus configuration
Now I realize I have no idea what I'm getting!!
Any Idea how much the voltage will sag from 37 when the trans is loaded with 500watts?
Mark
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 24th December 2001, 04:14 AM   #12
GRollins is offline GRollins  United States
Mark,
Some thoughts:
--Those transformers have four separate secondary windings. You'll be running two pairs of wires in parallel for each rail. Be careful hooking them up; make sure you don't get them backwards.
--The 37.5VAC from those transformers will give you a rail of approximately 51VDC (unloaded) assuming a cap input filter, after taking rectifier losses into account.
--No, it won't sag more than a few volts...or rather, by the time it does the transformer will be getting very, very hot indeed. You don't want it to sag that much, trust me. Count on, say, 48-50VDC rails under a reasonable load.
--A SOZ running on 48V rails is not a reasonable load. It's a current hog travelling incognito. A transformer to give +-48VDC rails will have to be rated much higher than 1010VA to withstand the SOZ circuit.
--But...there's a possibility that things might just work out. If, instead of a cap input filter, you were to use a choke input, the (loaded) DC rail would be more on the order of 35VDC, which is closer to what you had intended. A fringe benefit is that choke input filters deliver proportionately more current than cap input filters.
--Note that the caps in a choke input filter will rise to the full 51V unloaded, so buy 63V caps just to be sure you're prepared for any contingency.
--You're still going to need a bodacious amount of heatsinking, no matter what. (If all else fails, you can water cool the thing.)
--Now your only problem is to track down large chokes...or wind your own. (Don't worry, they're easy.) Take this slow and careful and you'll do just fine.
Grey
Old 24th December 2001, 06:27 AM   #13
diyAudio Editor
Variac's Avatar
Default 1010 Transformer angst
Well, thanks for the kindly advice.
I was able to determine from the Pass web pages that the voltage was too high. I just had the ignorant hope that the fact that the transformer was measured without load was significant.
I have now learned that rectification raises the voltage. sometimes learning can be painful! To Nelson Pass's credit, he states that the transformer should be rated 20% less than the rail voltage desired.
A choke would certainly put me in trendy company.
After hearing about the results Musical Fidelity is getting with this approach, I was tempted to ask NP about incorporating one.
I have always suspected that some of the "tube magic" was due to things other than tubes- I think even Mr. Pass has theorized that tube circuits are generally required to be simple and that this simplicity might be one of the major tube "advantages". Now the choke regulation is looking to be significant also.
So- two more questions
1. (you knew this was coming!!!) what sort of specs would a choke of this type have?-back to cruising the web!
Do they have to be wound on a core? I suspect there is more to it than just putting the choke in(where?) What else do I need?
2. I have already ordered the the 120,000 mfd of caps/ch mentioned in my original post above. BUT I also have 2 10 amp variacs.
Can I just use one on each amp and keep the AC voltage turned down to about 70 volts to the trans? (match both channels with a voltmeter)I think the toroid transformer would still handle the same current-right?
3. I could order the plitron toroids- but there's that pesky divorce possibility!
Thanks, Mark
Old 24th December 2001, 07:07 PM   #14
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I've been very happy with the ERSE inductors from
Zalytron (www.Zalytron.com) which can take a lot
of DC current before saturation.
Old 24th December 2001, 08:48 PM   #15
Super_BQ is offline Super_BQ
Super_BQ's Avatar
Send a message via ICQ to Super_BQ Send a message via Yahoo to Super_BQ
Default Inductors
Check out the supersize inductors i've made for my SoZ
http://www.geocities.com/super_bq/soz3.html
Future upgrade would be to move the amp to run at an even higher output wattage for running less efficient speakers. The amp is definitly over heatsinked so with the right transformer, I estimate it could easily do a total of 80 watts output maybe 100 watts.
Power turn on surge hasn't been too much of a problem for me right now. However, i'm curious what a 4KVA toroidal could pull from 240 VAC mainlines? I know 2KVA seems more of a problem to those living in countries with 120 VAC power.
Old 24th December 2001, 10:22 PM   #16
diyAudio Editor
Variac's Avatar
whoeee!
a post from Jolly St. Nelson on Christmas eve! Are the Erse inductors being proposed for the chokes?
My resistors and transformers arrived today but I'm not allowed to look at them till manana
Even if the variacs save me this time (do they?) I'm still pretty interested in the choke thang.They Are the design flavor of the month, after all. AND they would allow me to run the amp without the variacs if I put in a soft start gizmo. I hope even a choke approach uses some of these caps I bought! Any disadvatages to the chokes? (other than even more money no doubt!)
Mark
Old 29th December 2001, 10:00 PM   #17
diyAudio Editor
Variac's Avatar
Default Choke supply
Mark,
Well, I guess my 15 minutes of fame are over. I just assumed that Nelson Pass and Grey Rollins had dropped everything (including Christmas) to work out the details of a choke regulated power supply!
I assumed that the choke that Grey mentioned was different than the pi filter supply - is it? or were you just suggesting a higher value for the inductors. I have no fear of winding them, actually I like mindless work like that!
I'll fire it up with the variac, which will let me determine how much power the assembly can take, then maybe order Plitrons at that voltage later.
another option: I have heard of people unwinding transformers a bit to lower the volts. My assumption is that the amperes the transformer can handle remains the same, so the VA rating of the
transformer goes down. Thus, my 1kva trans becomes a .8 kva if I reduce the secondary to 80%? I assume I am still ahead because there is less voltage pushing current into the amp?
Actually, I am well on my way. The resistors I got are perfect, and mounting all 39 of them on my heatsinks will keep me busy.
To sum up:
Grey, what is this choke supply? values?
Will the variac solve the problem for the moment?
Anyone have some matched MOSFETS to sell?
gotta go,
Mark
Old 30th December 2001, 02:14 AM   #18
Mark,
A PI filter is rectifier->cap->inductor->cap, but there are other options. You can use an inductor as the first element: rectifier->inductor->cap, which is what I was referring to. It's called an "L" filter, by the way, since it looks like an upside-down, backwards capital L. Yes, you can keep on chaining these things out into the distance for as long as your wallet and patience hold out, but after about two or three stages you're well into diminishing returns.
Values? Whatever you can find to throw at it. Bigger is better in all cases. I looked at the inductors Nelson mentioned at one point, but can't remember what values they had. Hit their website and look things over.
The formula for reactance of an inductor (aka choke) is X= 2*PI*F*L where
X= reactance--kinda like resistance, but it varies with frequency--this is in ohms
F= frequency
L= inductance of the inductor in Henries (not millihenries or whatever, be sure to get the decimal in the right place)
We could get into things like the Q or stray capacitance of the inductor, but let's leave that for the time being. To a first approximation, the one formula above will do the job.
You'll be looking for an inductor with as low a DC resistance as you can get (larger gauge wire is the ticket, here), but with as high a reactance as possible at whatever frequency you're trying to filter. In this case, you're looking to knock out stuff in the 100Hz (if your AC line frequency is 50Hz) or 120Hz (if your AC is 60Hz) and above in multiples or either 50 or 60Hz.
Sit down with a calculator (or spreadsheet) and work it through. It'll soon start to come clear after you've fiddled it through.
Bear in mind that even a little bit of inductance helps, particularly with very large caps.
Grey
Old 31st December 2001, 07:32 PM   #19
The one and only
Try to use your 15 minutes sparingly. Me, I figure I've got
4 minutes left.
Old 31st December 2001, 08:35 PM   #20
diyAudio Editor
Variac's Avatar
Well Nelson, you are an immense fish (metaphorically - I don't know what you look like!)
in a pond that is perhaps smaller than we imagine.
For this reason, I think you still have quite a bit more mileage
on the fame o meter. Try to stay out of People magazine!
I suppose you have a better perspective in that you have to
market to this puddle.
Grey Rollins:
I have now learned a bunch, thanks to you both.
I promise to order a copy of Art of Electronics as soon as my funds recover from all the Zen stuff (ironic, huh?)
I now know that the pi filter WAS a choke supply.
I know where to get the coils (those Erse coils ARE a good value- cheaper than many, before considering performance)
I had always planned for this supply as Nelson has it shown with the pi filter on his site. It sure fits the amp design conceptually:
bigger is better!
Here are a few more questions :
the (square) rectifier bridge has one pin that is different next to the cut off corner. Which connection is this? the one to the ground?
If I parallel inductors, the current capacity clearly would go up.
What happens to the inductance- the same? Double?
No rush, still gotta track down the transistors
mark
Some Q about BSOZ PowersupplyHide this!Advertise here!
BSOZ Question- Caps and Rs lgreen Pass Labs 3 10th July 2003 02:46 PM
can somebody convert the BSOZ gerberfile to something usable??? hifi Pass Labs 20 5th January 2003 05:23 PM
Irf520N for BSOZ? CH2 Pass Labs 3 18th December 2002 09:38 AM
BSOZ using R15 & P5 as volume control Super_BQ Pass Labs 1 12th August 2002 07:31 PM
sound of a constantcurrentsource for BSOZ? joe Pass Labs 1 23rd October 2001 09:22 PM
