I have just finished my BOSOZ and wanted to check input and output connections before testing. I have one balanced and 3 single-ended inputs and balanced outs with single-ended RCAs in parallel with XLRs - RCA connections taken from the +ve XLR connections.
My question is: when using single-ended inputs and output, should the -ve input and -ve output on each channel be shorted to earth or only the -ve inputs ? I have seen mention of connecting the -ve to earth through a resistor-do I need to do this or connect direct to earth? Any help gratefully received!! |
#2 | |
#3 |
Wow, figure out the answers yourself!!!
#4 | |
if you have unbalanced source- then you must tie - input and gnd on that preamp input xlr (or in cable xlr jack itself) if you have unbalanced input on amp- you must tie - output pin and gnd ,also best place for that is on output cable XLR jack itself conclusion : leave preamp alone of all that shorting jobs and make all that in input and output XLR jacks ; in that manner- you need to have only XLRs on preamp case,no nasty RCA-XLR mix for testing purposes - short whatever you want ........ inputs,outputs.......again - counting on real life situation you expect with your sources and output amp(s)
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#5 | |
Steen |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| What are XLR connections?? | JuNA | Pass Labs | 30 | 24th November 2005 06:47 AM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Page generated in 0.08917 seconds (75.69% PHP - 24.31% MySQL) with 10 queries |
