Old 4th September 2007, 07:39 PM   #1
bays_9a5tt's Avatar
Default balanced source to unbalanced amp?
A friend of mine promised nice gift for me: CD player with balanced outputs. My equipment have unbalanced inputs (BoZ and Zen v2).
I know there is dirty trick by shorting one of balanced outputs to the ground but I'm concerned about signal distortion and/or noise.
Quick search yielded this op-amp adaptor:
http://emusician.com/diy/emusic_build_em_level/
Can you please comment adding this adapter to my system in order to use full potential of new CD player.
If not, oh well. I'm going to build another amp with balanced inputs
Old 4th September 2007, 09:02 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: balanced source to unbalanced amp?
just go and build another amp with balanced inputs ;
too many OPs ; frankly- even one is too much
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 5th September 2007, 03:22 AM   #3
Steve Eddy's Avatar
Default Re: Re: balanced source to unbalanced amp?
Or simply add a good input transformer to his existing amp.
se
Old 5th September 2007, 07:28 AM   #4
dejanm is offline dejanm  Austria
must read:
http://www.jensentransformers.com/an/an003.pdf
Old 5th September 2007, 01:53 PM   #5
Using only one of the signal phases of a balanced line does not inherently generate distortion. Likewise, it does not generate noise.
You don't short one output to ground. You short the unused phase of the input to ground. Leave the unused output phase alone.
Avoid opamps. That particular cure is worse than the disease.
I'm neutral on transformers. I've used them in tube gear with good results, but avoid them in solid state because they're generally unnecessary. This is one such case.
Grey
Old 5th September 2007, 05:55 PM   #6
The one and only
Nelson Pass's Avatar
If you build yourself a Balanced line stage (AKA BOSOZ) and
use it to drive bridged ZV2's, you'll probably think you've died
and gone to heaven.
Old 5th September 2007, 06:01 PM   #7
Steve Eddy's Avatar
and gone to heaven.
Rather cold comfort if you're an atheist.
se
Old 5th September 2007, 06:08 PM   #8
Steve Eddy's Avatar
Could you expand on that a bit? I'm not seeing why they would be any more or less necessary for tubes vs. solid state.
se'
Old 5th September 2007, 06:53 PM   #9
Output transformers. Yes, it's possible to do without (e.g. Atma-Sphere), but at the time I was building "normal" amps.
And, yes, it's possible to use output transformers for solid state. The best known example being McIntosh (okay, an autoformer, if you want to be picky), but it's best to avoid them if it's possible. Like caps, they influence the sound. You do without if you can...if you must use one, pay whatever the going rate is for a really good one and go on to the next thing.
Grey
Old 5th September 2007, 07:20 PM   #10
I see Nelson (if you don't mind me referring to you like that) has beaten me to it.
Just choose another balanced Pass Product to suit your tastes.
regards Andrew T.
aleph p1.0 - balanced in to unbalanced out recstar24 Pass Labs 0 11th November 2008 08:14 PM
Unbalanced to Balanced mcash257 Parts 3 14th October 2004 12:03 AM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
unbalanced or balanced theturtle Everything Else 4 5th January 2003 04:52 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Page generated in 0.11271 seconds (77.94% PHP - 22.06% MySQL) with 10 queries
