Old 2nd September 2007, 11:24 PM   #1
Default Mini Aleph Questions
Hi, I have a few 12.6V Hammond transformers lying around (this one http://www.alliedelec.com/Search/Pro...&tab=specs#tab ). Would these be suitable in making Mini Alephs? And I don't know how to make the power supply section. Does anyone have the schematics for them? Any help would be appreciated
Old 3rd September 2007, 02:16 AM   #2
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
The current is a bit low, but if you use the mini-a schematic as is, it might be just enough. The mini-a as is runs around 1 amp. Use 1 transfo for each channel.
Here's a very helpful site for beginners.
http://sound.westhost.com/psu-wiring.htm
Old 3rd September 2007, 02:47 AM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
This should work, but like vdi_nenna said, id use one per channel.
Old 3rd September 2007, 03:24 AM   #4
traw is offline traw  United States
actually looks like 2 per channel, 4 total, since each is 12.6. one per rail per channel. if tried just 2 at one per rail, would take a beating and likely sag down to 12-13 volts.
Old 3rd September 2007, 03:31 AM   #5
The voltage looks low. The 12.6 V centre-tapped
transformer will give you around +/- 8VDC rails. This
is too low for an Aleph.
What you can try is to discard the centre tap and use
two transformers to generate the +/- rails. That
should get you around +/- 16V DC.
The current capacity of the transformers isn't that high
so you may find that running two channels off this
one pair of transformers will cause the transformers
to get too hot. If that's the case, you can use another
pair for the second channel.
Dennis
Old 3rd September 2007, 05:07 AM   #6
Banned
I think we are all just sayin, buy a 30$ transformer off ebay and play it safe
Old 3rd September 2007, 03:02 PM   #7
Alright, thanks for the replies. I think I'm better off buying transformers that are more suitable. Thanks again!
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
mini aleph build questions mr.duck Pass Labs 33 11th May 2009 05:00 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Page generated in 0.08134 seconds (81.22% PHP - 18.78% MySQL) with 10 queries
