Hello Mr Pass and everybody.
I own a Thiel system (2.4 and PCS, 4 ohm 87db), and in order to listen to the hundreds of multi-channel SACDs I have, I just bought the Bel Canto Pre6 Gen2, which is one of the rare and maybe the best pure analogue (no AV) multi-channel preamplifiers there is out there. I wanted to use different power amps, but since my room is small one box would be better. I can have a good deal on the Pass X5 or the Simaudio Titan, and would incline more for the Pass. What would be the sonic differences? Also I understand that the Pass X5 was designed to sound better with XLR for all channels than single-ended, am I correct? Also, the 4 ohm 87db Thiels are not easy to drive and I was wondering if the X5's 125/ch in 8 ohm would be enough. |
#2 |
The one and only
I haven't heard the Simaudio product, and so I have no basis
for comparison. The X5 would be expected to behave itself into 5 channels of 4 ohms, but a lot would depend on how hard you want to push it. At some very loud level it will tend to shut off. As always, your best bet is to try the amplifiers out and see before you purchase.
#3 |
Thank you mr Pass. And also what about the XLR vs RCA? Are Pass Labs products designed to sound better with XLR?
Thanks a lot to everyone! |
#4 | |
Nelson has answered this in other threads. He's says that balanced xlr is superior to RCA for noise reduction, plus you need balanced inputs to fully take advantage of the X design. -David |
#5 |
The one and only
At the same time, there is only a modest difference between
balanced and SE inputs. I would say it's not enough to make you run out and buy a balanced preamp unless you have noise issues in your system.
#6 |
Ok, thank you very much.
| Hum left channel on Threshold SA3 (I know its not a pass labs but...) | Tino | Pass Labs | 3 | 30th May 2008 02:53 PM |
| fullrange speakers and Pass labs amps | MikeW | Pass Labs | 41 | 23rd March 2008 11:59 AM |
| JM Labs & Focal - Centre channel / Difference between Midrange & midbass speakers | mark.carline | Multi-Way | 5 | 18th May 2004 06:03 PM |
| Multi purpose multi channel gainclone PCB: Team project - group buy | rick57 | Chip Amps | 14 | 29th March 2003 05:54 PM |
| Cheap speakers to go with Pass Labs Son of Zen amp | dlharmon | Multi-Way | 3 | 30th December 2001 04:09 AM |
| Page generated in 0.07306 seconds (82.53% PHP - 17.47% MySQL) with 10 queries |
