Hi ! Am wondering if anyone has a sugestion for an amp to build from pass? lve built a couple chip amps and have just refurbed a yamaha p-2200 with a nice new alluminium face aswell which is for my sub woofers. l wanted to BI-amp my system but maybe its really a tri-amp set up(sub/mid bass/high?) l wanted to use the new 20watt class A amp from Silicon Chip mag for my high's and then was going to use a valve amp for mid/bass(EL34 push pull) and then use my subs for the low end as valve amps dont have the tightness in the lower bass region(debateable lm sure!!) But thats the general idea anyway. Now lm thinking of going for a non valve unit and useing perhaps a PASS amp as the amount of good reports aswell as the amount of good help at hand makes me feel that this is perhaps the better idea.l did think of useing the SKA amp but feel its not going to last long before l end up changing and useing something else . l would love to build once and leave alone to enjoy(lm sure thats what many of you wanted before you got bitten with the DIY thing!!) l can only hope anyway! Any ideas would be great. l live in Melbourne Australia so any local advice would be great too.
Thanks to all who have taken the time to read this and look forwards to replies . Cheers Shaun P.S yes....l was not paying attention in my english class!!(spelling) |
#2 |
Hi
I also moved form valve to solid state amps - although many years ago in my case. Solid state can offer better top end and base although valves are smooth in the middle. Nowadays a vfet is similar to a triod/pentode and you can get n and p devices which helps. If you want to try a Pass amp the Aleph series are very good and are single ended class a amps- so they should be familiar in layout. There are a number of models depending on the power you want from 30 watt upwards. There are also threads for Pass X amps which offer more power particularly in the base. However if you really nead base look at Pass diy which includes some class A Pass amps in push pull mode, such as the A75. I would have a good look at Pass diy. The Aleph 30 is good as is the aleph 1.2 and 2. The A75 is also good. I have built all of the foregoing and like them all. I think the Alephs are a good starting point. Don |
#3 |
The one and only
The best bottom end amplifier of the offerings is the
A75, I think.
#4 |
can I use 8 instead 6 transistors in alpeh5 clone
regards |
#5 |
The one and only
Of course.
#6 |
HI I've been looking at class A amps for a while. I started on the Aleph 1.2's but soon realized what a monster it is!!
Anyway, i think i want to build the A75. i would like to know where i can get info on it such as schematics, boards, etc... Thanks in advance. Any and all advice welcomeGreg! |
#7 |
i don't know why i'm under moderation. i've been a member (albeit silent) since 2005!!!
#8 | |
Beware, there are a few mistakes on the boards. There are a couple of threads here on the A-75--take a look at them. Sorry to burst your bubble, the the a-75 is not just a monster, but a TITAN, surely not easier than an aleph 1.2. The Mini-A is a great amp though, and much easier. JJ |
#9 |
hi jupiterjune
first- i was talking about the aleph 1.2 as being the 'monster'. if my memory serves me the aleph 1.2 is 200W of class A power. i'm not sure but i think the A75 is only 75W of Cass A. in which case smaller everything. IE trans, caps, electricity and most of all HEAT..i have heard about class A and now i want a taste, without the whole block dimming when i turn the beast on!!! i have martin logan sequel 2's and they are GREAT. i have been driving them with B&K M200 mono blocks and they sound good. anyway the ML's are electrostats and need current and i don't think the mini-A will drive them to sonic glory. thanks for the advice (always welcome) |
#10 |
Will the F4 drive them?
Crazy Yankee. |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Paging Mr. Pass, Mr. Pass pull my finger please. | khundude | Pass Labs | 2 | 5th December 2008 04:11 AM |
| Pass Tharagard A75 vs Pass Aleph 1.2's | daly41k | Pass Labs | 7 | 18th February 2007 03:10 PM |
| Amperes of Pass amps & Pass for ESL | rick57 | Pass Labs | 3 | 4th August 2005 03:28 PM |
| My opinion on Pass Labs and Mr. Pass (Nelson) himself | b_online | Pass Labs | 11 | 21st May 2003 12:39 AM |
| Page generated in 0.09011 seconds (87.68% PHP - 12.32% MySQL) with 10 queries |
