Is high frequency rising-up OK?
Old 4th August 2007, 12:54 PM   #1
Peter Huang is offline Peter Huang  Taiwan
Default Is high frequency rising-up OK?
I am studying an audio preamp. The following diagram is the simulation of ac frequency response when the circuit gain is set to be very high. I am afraid the condition will result any kind of disaster, such as break speakers. Any suggestion will be appreciated.
Old 4th August 2007, 06:40 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
A circuit with that big a peak might become an oscillator under
some conditions. Even if it doesn't, usually a peak like that
has an audible signature.
Old 4th August 2007, 06:56 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi Peter,
That will most likely break into oscillation on some portion of the signal. It may be much worse in real life also.
I think Nelson was making an understatement when he said ....
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 4th August 2007, 11:32 PM   #4
Thanks a lot.
Now I know what it means.
I may take a try specially carefully, step by step.
Thank you very much.
Peter Huang
Is high frequency rising-up OK?Hide this!Advertise here!
Why Scanspeak rising frequency response in woofers?? Daveis Multi-Way 5 3rd December 2011 07:54 PM
Taming rising frequency response 'naturally'... Taperwood Full Range 31 12th May 2006 03:50 AM
How would you aproach this rising frequency response? swak Full Range 6 4th November 2004 09:30 PM
Copyright ©1999-2017 diyAudio
