#51 |
Check your string of zener diodes. With the power off check the resistance of the zener string to ground. If its a short try lifting one lead in the string to open the circuit. You should then get a capacitance multipier with the output of the regulator 4 volts less than the input. Use a dummy load so you don't ruin your preamp while testing.
BDP |
#52 |
Finally, it's fixed! I replaced all the zeners and it's now feeding the preamp circuit without blowing fuses.
Thanks for all your help!! Vince |
#53 |
BTW- The sound is killer!!!
| BOSOZ Hum Problem | hifileslie | Pass Labs | 12 | 18th September 2007 04:28 PM |
| Bosoz psu problem | vit | Pass Labs | 10 | 21st August 2005 10:10 PM |
| more bosoz problem. when will it end! | cowanrg | Pass Labs | 16 | 20th July 2005 05:51 AM |
| BOSOZ PSU problem | tcl2 | Pass Labs | 7 | 5th July 2004 03:08 PM |
| Bosoz PSU problem | CH2 | Pass Labs | 3 | 28th June 2003 04:08 PM |
| Page generated in 0.06250 seconds (69.18% PHP - 30.82% MySQL) with 10 queries |
