A lot of Aleph boards have dual ground connections -- one
for the input and another for "the ground". To his credit, P. Daniel's board has an option to separate the two. I thought that using dual grounds is likely to create a ground loop that could cause hum. In other types of amps circuits (e.g., Leach amp) I see where a dual ground would be helpful to keep input and output stage grounding separate. But this doesn't apply to the Aleph. Can I just keep input ground and do away with the other ground connection ? |
#2 |
Should have mentioned that I have the ground shielding of my RCA jack
connected to a star ground point. My question is whether I need to have another direct connection from star ground to the pcb. |
| OPT grounding question | Nihilist | Tubes / Valves | 16 | 2nd June 2009 02:06 AM |
| quick grounding question | gain | Power Supplies | 7 | 22nd October 2008 03:19 PM |
| Grounding the Aleph 2 | Bakmeel | Pass Labs | 3 | 14th December 2007 02:53 PM |
| LM1876 Grounding Question | Dxvideo | Chip Amps | 6 | 5th October 2006 01:39 PM |
| grounding question | skyraider | Chip Amps | 1 | 9th March 2004 09:12 AM |
| Page generated in 0.06808 seconds (71.97% PHP - 28.03% MySQL) with 10 queries |
