I want to build 2x monoblock aleph5, in spec it's said that the power consumption is 300W, is it 300W for a stereo amp or 300W per channel? Where to physicly put both thermistor ? Does TH2 must be stick to the toroidal tranny ? For the LED, is it a good old small red one ? Thank for your reply ! |
#2 |
Lightning In A Bottle
If 300W came off the stock Aleph 5 spec sheet, that is for stereo power consumption as the original design was in a stereo chassis.
TH1 acts as current surge limiter at power up when the PS caps charge up from 0V. Directly soldered to one leg of the Thermostatic switch is a good idea. Make the wire connecting TH2 as short as possible and positioned as close as possible at the Earth terminal of your AC plug. For LED it is blue in the Pass Labs products but is not mandatory...whichever looks to you.
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
| 2 quick SI questions | Decker | Class D | 2 | 26th November 2007 11:30 PM |
| 2 quick questions | JPeitzman | Chip Amps | 7 | 22nd July 2007 05:27 PM |
| 2 quick questions | Lowjacker | Car Audio | 3 | 8th July 2006 03:32 AM |
| A few quick newbie questions | judtoff | Chip Amps | 2 | 20th July 2005 12:08 AM |
| quick questions | theChris | Multi-Way | 0 | 12th February 2003 04:54 AM |
| Page generated in 0.08180 seconds (69.43% PHP - 30.57% MySQL) with 10 queries |
